SMath Studio Forum
Samples
Method A.B. Draghilev and animation spatial mechanisms
Application of the method A.B. Draghilev to the calculation of the kinematics and animation spatial mechanisms developed prof.A.B.Ivanov, that develops method A.B. Draghilev to solve practical problems. Their development, with detailed explanations, he published on the site http://forum.exponenta.ru/viewtopic.php?t=12842 The following examples are taken from this site and transferred from Maple in the programming environment SMath Studio. A huge thanks to Alexei Ivanov, who gave me great help in the study the method of A.B .Draghilev. 1.Explanatory example http://ru.smath.info/for...matsii-miekhanizmov.aspxEdited by user 26 January 2014 10:13:25(UTC)
2 users thanked Ber7 for this useful post.
on 31/01/2014(UTC), on 07/05/2016(UTC)
One end of the rod moves in the spatial curve, the other along a circular arc.
3 users thanked Ber7 for this useful post.
on 26/01/2014(UTC), on 31/01/2014(UTC), on 07/05/2016(UTC)
Three-link spatial mechanism Edited by user 14 September 2015 13:28:52(UTC)
| Reason: Not specified File Attachment(s): Pr4.smz (10kb) downloaded 88 time(s).
Spatial four-bar linkage1 Spatial four-bar linkage 2 Artobolevskij.smz (11kb) downloaded 67 time(s). Primer5.smz (47kb) downloaded 133 time(s).Edited by user 09 November 2015 11:46:02(UTC)
Cardan Mechanism.The axes of rotation intersect at an angle of 45 degrees Edited by user 21 May 2014 16:59:17(UTC)
on 19/04/2014(UTC), on 07/05/2016(UTC)
The line of intersection of the torus and sphere(Villarceau circles)This example is taken from an article by Дубанов А.А. :Численно-аналитическое построение линий пересечения поверхностей методом Драгилева,2007(rus) http://www.blagovest2002...urfInt/paper1/Paper1.htm
on 05/05/2014(UTC), on 07/05/2016(UTC)
Originally Posted by: Ber7 Cardan Mechanism.The axes of rotation intersect at an angle of 45 degrees The same mechanism with spherical linkages These linkages have the property that every link in the system rotates about the same fixed point. Thus, trajectories of points in each link lie on concentric spheres with this point as the center. Only the revolute joint is compatible with this rotational movement and its axis must pass through the fixed point. Edited by user 07 November 2015 19:15:45(UTC)
on 12/05/2014(UTC), on 16/05/2014(UTC), on 07/05/2016(UTC)
I can't see the last image (neither in the russian side of the forum) |
Ring instead of cross-piece
on 19/07/2015(UTC), on 07/05/2016(UTC)
3-PRS Parallel Manipulator Edited by user 31 August 2015 00:03:26(UTC)
The Delta Parallel RobotKinematic scheme and dimensions are taken from the book R.L. Williams II, “The Delta Parallel Robot: Kinematics Solutions”, Internet Publication, April 2015. Delta.smz (506kb) downloaded 165 time(s). Delta.pdf (543kb) downloaded 239 time(s).Edited by user 15 November 2015 23:50:53(UTC)
on 01/09/2015(UTC), on 02/09/2015(UTC)
on 14/09/2015(UTC), on 07/05/2016(UTC)
Again The Delta Parallel Robot.Winding onto a cylindrical mandrel
on 24/10/2015(UTC), on 07/05/2016(UTC)
Delta3.smz (601kb) downloaded 73 time(s).Version for conical spiral Edited by user 28 October 2015 19:05:16(UTC)
on 21/11/2015(UTC), on 07/05/2016(UTC)
Delta0C.smz (322kb) downloaded 107 time(s).In the above animation three links that support the lower platform is a simplified and presented in the form of red rods. Actually used parallelograms (pantographs), where top and bottom mounted universal (cardan) joints. Each universal joint implemented using Three revolute joints . The axis of the middle joints lies in the plane of the parallelogram, and axis external joints perpendicular to this plane. Animation of this design is shown below. Edited by user 21 November 2015 14:39:55(UTC)
on 07/05/2016(UTC), on 09/05/2016(UTC)
1 user thanked Ber7 for this useful post.
Thanks Ber7 for your repost/new animations. Some don't work in Smath 5346, so what. Animation is a very nice feature from Smath. Jean Rotate XY.sm (475kb) downloaded 44 time(s).
SMath Studio Forum
Samples
