4 Pages<1234>
#21 Posted : 23 August 2013 12:54:57(UTC)
Was thanked: 1334 time(s) in 877 post(s)
UPDATED
- command-line options
syntax: 'ProcessToStart'[space]Flags
[edit] - Graphical adjustements
Edited by user 24 August 2013 01:06:25(UTC)  | Reason: Not specified
on 23/08/2013(UTC)
#22 Posted : 23 August 2013 17:27:19(UTC)
Thanks for the fast reaction. Hyperlink is simply great. I find myself launching applications using
Ctrl-H "command +Click
on 24/08/2013(UTC)
#23 Posted : 26 August 2013 21:14:20(UTC)
UPDATED
Just to complete the early introduced feature Good
- converter on paste accept command-line strings (input string: "ProcessToStart"[space]Flags)
so when you paste in the placeholder something like:
Code:
"C:\Windows\system32\rundll32" sysdm.cpl,EditEnvironmentVariables
this will become:
Code:
"'C:\Windows\system32\rundll32' sysdm.cpl,EditEnvironmentVariables"
best regards,
Davide
Edited by user 26 August 2013 21:16:36(UTC)  | Reason: Not specified
#24 Posted : 28 August 2013 10:18:31(UTC)
Strange bug: If you copy a Hyperlink region with description using Ctrl-Drag, then both original and copy seem to use the same data. If you edit the copy, the original changes as well (also the cursor is shown there).
Playing around with empty/nonempty or visible/nonvisible description prior to copying shows other glitches like frozen box size in the copy description. That might be secondary symptoms of the data handling problem.
If you copy using Ctrl-C Ctrl-V everyting is fine.
Edited by user 28 August 2013 10:20:44(UTC)  | Reason: Not specified
#25 Posted : 28 August 2013 11:04:39(UTC)
thank you, was my fault. Plugin updated.
on 28/08/2013(UTC)
Offline sublim21
#26 Posted : 11 September 2013 21:51:48(UTC)
sublim21
Was thanked: 3 time(s) in 3 post(s)
Just found out about this plugin.
Thanks for the work man.
Just a few quick questions,
lets say i wanted to open up a file with a specific program, what would i type into the hyperlink?
for example, lets say i wanted to open up
song.mp3
with the executable
C:\foobar\foobar.exe
#27 Posted : 11 September 2013 22:13:36(UTC)
song.mp3
with the executable
You might try the approach shown in post23.
Use "'C:\foobar\foobar.exe' song.mp3". It is essential to quote the executable path with ', otherwise windows takes the space as part of the prog name.
#28 Posted : 12 September 2013 00:50:46(UTC)
Exactly Good
with foobar, if your song contains some spaces use wildcards (*) instead of spaces (f.e. this doesn't work in vlc; I'll think to another approach or another solution to fix this - maybe a double single quotation to have a double quotation or a context menu dialog...)
regards,
Davide
Offline sublim21
#29 Posted : 12 September 2013 19:32:18(UTC)
sublim21
totally missed the apostrophes. Thanks for the update.
Amazing plugin websurfer.
#30 Posted : 07 October 2013 03:09:31(UTC)
UPDATED
- Flags input moved from the placeholder to a dedicated context menu item.
This solve double quotes issues involving flags and SMath strings.
- PASTE feature works also with the new input way.
(TEMPORARY feature) To update worksheets containing the old syntax ("'process' flags"):
- open the worksheet
- save the worksheet
- close and open again the worksheet
- delete all except the process name from the input placeholder
regards
Davide
Edited by user 07 October 2013 03:12:50(UTC)  | Reason: Not specified
on 07/10/2013(UTC)
#31 Posted : 08 October 2013 18:57:30(UTC)
UPDATED
- Fixed critical bug on exceptions' propagation.
#32 Posted : 02 February 2014 16:31:50(UTC)
UPDATED
- SMath Studio 0.96.5146 required;
- restored red background when the region is disabled;
- click on resize markers now doesn't trigger the link.
best regards,
Davide
Offline Andrey Ivashov
#33 Posted : 02 February 2014 17:02:47(UTC)
Rank: Administration
Thank you!
on 02/02/2014(UTC)
Offline dyleks
#34 Posted : 04 February 2014 13:48:12(UTC)
dyleks
Poland
I am using it with version 0.96.5146 but generation
of executable version (viewer) doesn't work for me.
Is that known issue ?
#35 Posted : 04 February 2014 14:08:28(UTC)
Hello, I can't reproduce the issue... could you attach a file that doesn't work for you?
Edited by user 04 February 2014 14:36:58(UTC)  | Reason: Not specified
Offline dyleks
#36 Posted : 04 February 2014 15:10:27(UTC)
dyleks
Poland
The issue is solved.
After SMath was restarted it works.
Sorry for bothering you.
#37 Posted : 13 February 2014 02:14:21(UTC)
UPDATED
- Paste as SMath string temporary disabled (this let you paste strings on the canvas freely)
Offline ziopaper
#38 Posted : 08 August 2014 02:13:00(UTC)
ziopaper
Rank: Member
United States
Hi guys,
not sure if it is my issue only, but everything I paste becomes an hyperlink, formulas also.
The way I am working now it starting a dummy formula, paste what I need and then delete the rest. Am I missing something?
I tried to find a reference to this in the forum but did not succeed. I apologize if the answer is already out there.
thanks
#39 Posted : 08 August 2014 15:34:49(UTC)
You're right, the cause is a known bug of the clipboard manager (SS-200). I've accidentally re-enabled the feature in some silent update related to API changes.
PLUGIN UPDATED
- Paste as SMath string temporary disabled.
edit not a SMath bug, just a misinterpreted feature.
Edited by user 08 August 2014 22:22:28(UTC)  | Reason: Not specified
on 08/08/2014(UTC)
Offline ziopaper
#40 Posted : 08 August 2014 19:26:19(UTC)
ziopaper
Rank: Member
United States
ok, thanks!
Guest (2)
4 Pages<1234>
