Offline sefc
#1 Posted : 11 February 2014 06:33:45(UTC)
sefc
United States
I am very new to Smath Studio and programming in general. I have been able solve systems directly in Maxima, but am having difficulty doing it through the plugin for Smath. Could someone please give me some tips for how to solve a simple system such as a car accelerating from a stop?
Say I know the distance and time that a car accelerates and I want to determine the acceleration and velocity. Obviously this is a very simple example to do by hand, but I want to understand the technique for how to solve this in Smath using Maxima.
Equations:
d=1/2*a*^2
v=sqrt(2*a*d)
Knowns(t,d)
Unknowns(v,a)
Thanks for the help!
Offline omorr
#2 Posted : 11 February 2014 10:56:40(UTC)
omorr
Rank: Administration
Serbia
Just look at the SMath Active Book by Martin Kraska and you will find under Maxima plugin the answer. For instance, you can use Algsys() function
L:Algsys(mat(d≡1/2*a*t^2,v≡sqrt(2*a*d),2,1),mat(v,a,2,1))
Assign(L)=sys(sys(2*abs(d)/abs(t),2*d/{t^2},2,1),1,1)
v={2*abs(d)}/abs(t) a={2*d}/{t^2}
on 11/02/2014(UTC)
Offline sefc
#3 Posted : 11 February 2014 19:46:40(UTC)
sefc
United States
Great, thank you so much omorr!
Offline sefc
#4 Posted : 12 February 2014 03:53:18(UTC)
sefc
United States
I went home and tried using that function tonight and keep getting an error message that the d and v are "not defined". Like I said, I am new to this and I am not quite sure what my mistake is. I really appreciate the help!
#5 Posted : 12 February 2014 03:59:34(UTC)
That is because you try to get a numeric result. If you use -> (evaluate symbolically) then you get the correct result.
You also can switch evaluation mode via context menu (right mouse button), entry "Optimization"
on 10/04/2018(UTC)
Offline sefc
#6 Posted : 12 February 2014 07:35:08(UTC)
sefc
United States
Wow, thank you both so much! That was super helpful. I need to go brush up on the basics.
Thanks again!
