Why this not working? uni attached the following image(s): |
Joined: 23/12/2011(UTC) Posts: 320 Location: italy Was thanked: 109 time(s) in 93 post(s)
because of caps? sergio
I use russian units. They do not work. I don't know is this a bug or not. English units are working fine. Edited by user 11 July 2014 11:11:47(UTC)
I managed to make a total mess by changing languages. I think this is something connected with Units also. (SMath nightly build 0.96.3501, x64 Win 7) See this video please changing languages problem (~5min long) Until I figured out how to get SMath back, I installed/unisnstalled it few times, Repair it few times etc. - but nothing helped until I I did as presented in the video - changed the language "blindly". Actually, I do not know how to completelly remove SMath from the system and make a "fresh" install? Regards, Radovan Edited by user 11 July 2014 11:30:53(UTC)
Thank you Radovan, now it works fine (default was English.). Edited by user 11 July 2014 11:46:09(UTC)
| Reason: Not specified uni attached the following image(s): |
Originally Posted by: uni Thank you Radovan, now it works fine. Uni, I do not understand . I can not use my languages in this build (neither Serbian Latin, nor Cyrillic) and if you and other people can do this, this must be my computer fault. I will try on some other computers to see if the problem persists. Regards, Radovan |
Please confirm all addressed in this thread issues are resolved.
Originally Posted by: omorr Originally Posted by: uni Thank you Radovan, now it works fine. Uni, I do not understand . I can not use my languages in this build (neither Serbian Latin, nor Cyrillic) and if you and other people can do this, this must be my computer fault. I will try on some other computers to see if the problem persists. Language problem I mentioned had been resolved see this linkRegards, Radovan |
