SMath Studio Forum
Bugs & Problems
sqrt(squared units) not working anymore?
I had a worksheet that worked in the past, but now it doesn't, saying "operation cannot be performed with units", because it's sqrt(V^2)? But if I break it up into two steps it works:
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,657 Location: Italy Was thanked: 1342 time(s) in 881 post(s)
Works for me with SMath 0.97.5301, but I see you are using 0.97.5154 Could you try to open your file with the latest Nightly build? Davide Carpi attached the following image(s): |
yes, it works in the Nightly build. thanks.
by the way, the email notification links never work. I always get
"There has been a serious error loading the forum. No further information is available.
Please contact the administrator if this message persists."
and have to find the topic manually
Actually, no, the original worksheet is not working, only the copy that I uploaded
I've already seen this bug, sometimes comes to light... when the SMath engine output unitary exponents on units, square root fails. Refreshing the worksheet alternately works/doesn't works. [EDIT] Added in the BTS: SS-177Edited by user 15 July 2014 01:20:03(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
SMath Studio Forum
Bugs & Problems
