Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,636 Was thanked: 2006 time(s) in 677 post(s)
Stable version of SMath Studio 0.87 will be available on 10 February 2010 Last changes - Dynamic Assistance technology implemented (Ctrl+space to manually activate; Tab, Ctrl+Enter, Shift+Enter, DoubleClick or *+Enter for Smartphones to accept current menu item). Option can be turned off using "Dynamic assistance" item of "View" menu;
- Added support for plugins;
- Teamwork Sessions implemented;
- Added ability to change Decimal Symbol and Argument Separator symbol through global options of the program;
- Controls Border on/off Toolbar button added to the main program Toolbar;
- Application Settings now stores in the Application Data folder of current user (no more permissions issues will appear on settings file save). Portable Desktop version still stores settings in the current application folder;
- Smooth controls moving implemented (affects on page controls location changing, on file opening and new page controls created from clipboard). Option can be turned off with manual editing of settings.inf file from Application Data folder;
- Desktop: New supported file types added to the Insert Image From File dialog: bmp, gif, jpeg, jpg, jpe, png and ico;
- Desktop: Added ability to insert images to the page using Drag'n'Drop;
- Example files added to Examples Dialog: Hermite Polynomials, Laguerre Polynomials;
- Added save files dependences (SMath Studio and plugins versions) check on file open;
- Added plugins dependences (SMath Studio and additional plugins versions) check on plugins load;
- Examples Dialog loading speed increased (especially for Handheld version);
- Substitution of the user-defined variables and functions speed increased;
- "Delete" keyboard button handler added to the Math Control;
- "Home" and "End" keyboard buttons now can be used inside Text or Math controls to move cursor to the end or to the start of expression;
- Desktop: Several icons added to the Main Menu;
- Desktop: Width of the Settings Dialog increased;
- List of Examples into Examples Dialog now sorted alphabetically;
- Not documented function fft(..) added to numeric library;
- Function if(..) improved. If condition is not '1' or '0' then error message will be shown;
- Functions wfile(..), rfile(..) and dfile(..) now works with ApplicationData/SMath/user directory;
- Handheld: Settings Dialogs improved;
- New rules implemented for Symbolic library: "sin/cos", "cos/sin", "sin*ctg", "cos*tg";
- Fixed calculation errors, when calculation was in progress in two or more threads (i.e. Pages) at the same time;
- Fixed issue when wrong Fraction Type option set after calculation of equation with manually specified Fraction Type;
- Fixed issue when it was impossible to insert special chars of Polish and some other languages (RightAlt+[char]);
- Fixed user interface synchronization issues when switching Page windows in the scope of one application process;
- Fixed wrong limit(..) function drawing;
- Fixed issue with changing MathControl to TextControl on space insert. Sometimes this cause creating of the text element with wrong location;
- Fixed error when Decimal Places option unexpectedly becomes equal to 15;
- Fixed calculation issues with nested diff(..), sum(..) and product(..) functions;
- Fixed error when symbolic calculation of round(..) function returns a mod(..) function;
- Fixed error when graphs couldn't be ploted;
- Numeric composition of Matrix and Complex number error fixed;
- Symbolic Boolean operators priority error fixed;
- Fixed symbolic differentiation error: "el(x;1)-el(x;2)=0";
- Symbolic calculation error fixed, f.e.: "arccos(-0,3536)";
- Numeric calculation errors fixed, f.e.: "5^{1/0.1}", "sin(sys(1;1,2;2;1))", (-2.1)^2="...+i*...", "(-1.1)^20=...";
- Desktop: Fixed critical error on edited pages closing, if user will Cancel closing of the second Page;
- Fixed error "A Graphics object cannot be created from an image that has an indexed pixel format." when insert some types of images to the page;
- Desktop: Fixed error when SMath Studio tries to open non SMath Studio documents on wrong type document(s) Drag'n'Drop;
- Desktop: Example Dialog Title corrected (symbol ":" removed);
- Fixed open wrong file issue: now if file was not parsed (or some other critical error appears) no new blank page will be created;
- Desktop: Fixed error happens in case of any exception while opening Save File: wrong font styles can be applied to the global options of the program;
- Handheld: "All files" type of the Insert Image From File dialog changed to accept only bmp, gif, jpeg, jpg, jpe, png and ico images;
- Desktop: Examples into the Insert Function Dialog and into Insert Operator Dialog are now centered;
- Export to HTML image id's order fixed;
- Indonesian language translation added;
- Indonesian language descriptions added to Examples Dialog files;
- Polish and Danish translations updated;
- Code optimization.
System requirements - Handheld:
Framework: .NET Compact Framework 2.0 cab (5,33МБ), zip (1,99МБ) Compatibility: Pocket PC 2002, WM 2003, WM 2003 SE, WM 5, WM 6, WM 6.1, full VGA support, all PPC's, Comunicators and smartphones.
- Desktop (Windows):
Framework: .NET Framework 2.0
- Desktop (Linux):
Interface languages Desktop и Handheld (22 languages): [ENG] English / English [GER] German / Deutsch [DAN] Danish / Dansk [DUT] Dutch / Nederlands [SPA] Spanish / Español [FRE] French / Français [POR] Portuguese / Português [CPP] Portuguese (Brazil) / Brazil (Português) [SCR] Croatian / Hrvatski [SCC] Serbian / Srpski [GRE] Greek / Ελληνικά [TUR] Turkish / Türkçe [CHS] Chinese (Simplified) / 简体中文 [CHT] Chinese (Traditional) / 簡體中文 [CZE] Czech / Čeština [HUN] Hungarian / Magyar [ITA] Italian / Italiano [POL] Polish / Polski [IND] Indonesian / Bahasa Indonesia [RUS] Russian / Русский [BUL] Bulgarian / Български [LTH] Lithuanian / Lietuvių [UKR] Ukrain / Українська
Free Download (Release Candidate 3)
Edited by user 10 September 2016 00:57:25(UTC)
