Offline nik
#1 Posted : 01 February 2015 05:11:42(UTC)
nik
Hi all,
some problem which unit calculation
K:8.87
α:1
β:0.43
γ:0
b:200*'мм
Kα:K*(α+(β*{α^2}/{b^2})+(γ*{α^4}/{b^4}))^0.5=#
result: Unit does not match((((
#2 Posted : 01 February 2015 15:39:04(UTC)
The error seems correct. Just make a dimensional analysis on α+(β*{α^2}/{b^2})+(γ*{α^4}/{b^4})
You sum something dimensionless with 1/мм^2 and 1/мм^4
Edited by user 01 February 2015 15:41:03(UTC)  | Reason: Not specified
Offline nik
#3 Posted : 03 February 2015 01:45:39(UTC)
nik
I`m not convert unit of measure, math operation only value. mm^4 you real?? what a dimension, square? cube or astral?
#4 Posted : 03 February 2015 02:11:26(UTC)
Maybe the attached picture helps a little bit more to understand the issue...
As stated previously, you can't sum apples and oranges; therefore the error message seems consistent...
Edited by user 03 February 2015 11:12:31(UTC)  | Reason: Not specified
Offline nik
#5 Posted : 04 February 2015 00:46:44(UTC)
nik
ок,
formula
Edited by user 04 February 2015 00:53:47(UTC)  | Reason: Not specified
#6 Posted : 04 February 2015 01:20:22(UTC)
Thanks for sharing the original formula, this makes more sense; seems you have missed or merged a parameter (alpha) with a variable (a)
Best regards,
Davide
Edited by user 04 February 2015 01:40:15(UTC)  | Reason: Not specified
File Attachment(s):
nik.sm (18kb) downloaded 16 time(s).
2015-02-03 23_17_48-Incorrect Unit calculation - Bugs & Problems - SMath Studio Forum.png
Offline nik
#7 Posted : 05 February 2015 00:04:59(UTC)
nik
this is font trouble, real value "a"
#8 Posted : 05 February 2015 01:20:46(UTC)
Seems strange, because in this way the formula has both mathematical sense (alpha*x^0+beta*x^2+gamma*x^4) and physical sense (homogenous units involved in the calculation)... there is some literature about this formula? (where it is used? has an author?)
Edited by user 05 February 2015 01:30:12(UTC)  | Reason: Not specified
