Offline studoc
#1 Posted : 16 April 2015 01:43:39(UTC)
studoc
Rank: Member
Stumped…
I have a small problem calculating a variable within a routine, that has worked before, but doesn't now..
Error is "units don't match".
When I look at the variables, the units are all the same.. don't see how I can trick the program into believing the this…
Now, I can't seem to paste an image in here and although I have checked the box marked, "attach files to this post" i can't see anywhere to upload files..
If someone could help me solve that problem in the first instance, the initial problem may prove to be a snatch..
Thanks..
File Attachment(s):
KP at rafters.sm (41kb) downloaded 27 time(s).
Offline PompelmoTell
#2 Posted : 16 April 2015 11:31:58(UTC)
PompelmoTell
You can use eval()
or ask the online evaluation with shift+=
#3 Posted : 16 April 2015 11:38:30(UTC)
The issue is related to the symbolic optimization. Switch the optimization of the definition to numeric to solve the issue.
About the attachments, check the button "Attach files to this post?" and click the POST button, you will be redirected to another page with a dialog to upload the files.
Edited by user 16 April 2015 12:48:15(UTC)  | Reason: Not specified
Similar Topics
Energy / Temperature "Units don't match" error (Bugs & Problems)
by Nalorin 30/11/2021 05:29:41(UTC)
Units don't match problem (Bugs & Problems)
by Eduardl 06/08/2016 19:09:41(UTC)
[SS-2368] Unit behavior - units don't match issue (Bugs & Problems)
by fred47 06/08/2016 02:19:36(UTC)
Units don't match - but units not used? (Bugs & Problems)
by omorr 08/05/2013 10:27:34(UTC)
