Dear all,
Daily I'm working on my smath file. Since the latest changes I get the following error while saving:
"Unexpected end of file has occurred. The following elements are not closed: input, math, region, region, region, region, regions. Line 35237, position 18."
The programm closes and the saved file cannot be opened any more. Does anyone know a solution?
Thanking you in advance,
Werner
You can (partially) fix the file by closing the missing xml tags (using a text editor).
To find the cause and fix the issue a reproducible sequence of actions or the file is needed (you may contact directly the developper if the file can't be shared here) |
Hello Davide, Originally Posted by: w3b5urf3r_reloaded You can (partially) fix the file by closing the missing xml tags (using a text editor).
To find the cause and fix the issue a reproducible sequence of actions or the file is needed (you may contact directly the developper if the file can't be shared here) Is there any way that someone can write a Recovery script which will fix the broken SMath file. I remember that I found long time ago some similar script for the corrupted Mathcad files. Regards, Radovan |
2 users thanked omorr for this useful post.
on 12/06/2015(UTC), on 12/06/2015(UTC)
I think is possible. Tomorrow I'll try to do something. |
Dear all,
I installed the latest nightly build version of Smath and since then I cannot reproduce the error any more.
