SMath Studio Forum
Bugs & Problems
[CustomFunctions] mat2sys.1() and plotting inconsistency
Hi All, I have been trying to plot a matrix containing multiple matrices by using the mat2sys.1() function to convert the matrix into a system of matrix first. I got it to work once, but could not get the same result by using the same codes after. Please refer to the attached, I have highlight the code that works in pink. If I copy and paste that exact line of code, it would work but it wouldn't if I just type in the same thing, I have demonstrated that in my attachment. I hope someone will be able to shine me some light on this. Thanks!!! Edited by moderator 20 May 2016 22:58:46(UTC)
| Reason: marked, as solved File Attachment(s): test.sm (13kb) downloaded 22 time(s). anothersmathuser attached the following image(s):
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,656 Location: Italy Was thanked: 1341 time(s) in 880 post(s)
Hello anothersmathuser, You have to change the optimization of the plot2 definition to numeric, because the special features of SMath systems. You can see what happens by holding your mouse over the plot1 and plot2 definitions. Davide Carpi attached the following image(s): |
It works, thanks for your help!
SMath Studio Forum
Bugs & Problems
