Joined: 15/07/2015(UTC) Posts: 13 Was thanked: 1 time(s) in 1 post(s)
Hi guys, i again... Today (like everyday) when i was working with the program and i wanted to save the document, the program crash and closed... Now when i open the document give me error (the image is attached). How i can resolve it? The document have so much work and do not want to do it again. Thanks again and i hope you can help me! File Attachment(s): Macs attached the following image(s):
Thanks for your help Ioan, and i have been downloaded the plugin but don't appear "File recovery" what should I do? Can you repair this document too pls? Edited by user 13 August 2015 23:23:24(UTC)
Originally Posted by: Macs i have been downloaded the plugin but don't appear "File recovery" what should I do? The plugin in which is included this option was made for SMath Studio 0.97.5581 (Nightly Build). Probably you are using an older version Edited by user 20 May 2016 22:46:22(UTC)
| Reason: marked as solved |
Originally Posted by: w3b5urf3r_reloaded Originally Posted by: Macs i have been downloaded the plugin but don't appear "File recovery" what should I do? The plugin in which is included this option was made for SMath Studio 0.97.5581 (Nightly Build). Probably you are using an older version Ah... good point. I have 0.97(5346) ... I would download the latest (or beta, is the same?) Edited by user 14 August 2015 15:18:30(UTC)
