After the update, plugin coolprop Wraper crashes. At an earlier version I manually installed coolprop 5.1.1 / 2 and everything worked. I tried to install an older version and it worked again two days now I have the same problem Of course I tried to delete both and install again only one, but I failed
"CooProp Wrapper" updated (made it compatible with the latest SS) Looking at the sources of "coolprop_wrapper" seems you need only to recompile it coolprop_wrapper is the official plugin, made by Mike Kaganski, "CooProp Wrapper" in the gallery is the clone of an early beta made by him and published by me. coolprop_wrapper contains more functions and coolprop's libraries always updated documentation and link to sources and binaries: http://www.coolprop.org/coolprop/wrappers/SMath/index.html#smathEdited by user 20 May 2016 21:02:06(UTC)
| Reason: marked as solved |
I don't see this plug-in in my list of plugins, where is this plugin located? Just curious.
thanks!
Originally Posted by: RFreund I don't see this plug-in in my list of plugins, where is this plugin located? Just curious. Did you try to turn on beta-versions of plug-ins?
That worked, thank you. I really thought I had unchecked that...
