3 Pages123>
#1 Posted : 11 February 2014 13:14:59(UTC)
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
  • requirements: SMath Studio 0.96.5146 or later;
  • installation: download the plugin from the gallery;
  • documentation: see Slider Region.sm (32kb) downloaded 70 time(s).;
  • sources: all the updated sources are available in the SVN repository.
>>> PLEASE REPORT IN THIS THREAD ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Control Regions: CheckBoxList | ComboBoxList | ConditionallyFormattedLabelNumericUpDown | PathPicker | RadioButtonList | Slider
Edited by user 30 December 2021 02:02:14(UTC)  | Reason: documentation updated
thanks 4 users thanked Davide Carpi for this useful post.
on 11/02/2014(UTC),  on 11/02/2014(UTC),  on 11/02/2014(UTC),  on 08/11/2015(UTC)
Offline omorr
#2 Posted : 11 February 2014 22:55:20(UTC)
omorr
Rank: Administration
Serbia
Hello Davide,
It seems that Controls menu item appeared twice under Insert with two of your plugins. On is Insert=>Controls=>Slider as well as Insert=>Controls=>Numeric up-down
Offline Andrey Ivashov
#3 Posted : 11 February 2014 22:55:25(UTC)
It's great! Thank you!
I noticed one minor issue: "=" keyboard button handled as "+" by the control.
Regards.
#4 Posted : 11 February 2014 22:57:47(UTC)
Thank you! Good catch! Good This is SMath Studio issue which will be fixed later. It is described here: http://en.smath.info/for...ns-having-childrens.aspx
Regards.
Offline omorr
#5 Posted : 11 February 2014 23:05:00(UTC)
omorr
Serbia
You are welcome,
By the way, it can be quite confusing an to long menu item without some reordering and grouping things of the Insert menu.
#6 Posted : 12 February 2014 02:35:04(UTC)
Seems a little big problem... I noticed now that english and russian layouts have "+" and "=" on the same key, and the plus symbol needs the SHIFT modifier; in the italian layout the "=" key is activated with the "SHIFT"+"0" combination and the "+" sign is in the same key of the "*", but is activated without SHIFT modifier.
So the question is: how I can use the Keys.Oemplus without localization issues? (because I suppose that the Italian layout is not alone in the universe of the keyboard layouts) Crazy
With the premise that it is not critical ("=" should not be used in this region), looking the web seems to me that the OnKeyDown is the wrong event to check this, the OnKeyPress probably should be better (but I'm not sure).
I think also that something is in the wrong place (like the Martin's Maxima items or my Development tools, these should be moved in the "Tools" menu - but this is a secondary thing)
Edited by user 12 February 2014 03:27:49(UTC)  | Reason: Not specified
Online mkraska
#7 Posted : 09 March 2014 01:27:10(UTC)
I'd propose to bind doubleclick to the settings menu, just like in the numeric-up-down region.
#8 Posted : 10 March 2014 13:32:08(UTC)
I will think about this; in one hand I don't like that the first click may change the thumb location, in the other hand this has not much importance accessing to the settings dialog...
Offline Ber7
#9 Posted : 13 March 2014 18:37:35(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
File Attachment(s):
Slider.rar (391kb) downloaded 88 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 14/03/2014(UTC)
#10 Posted : 14 March 2014 02:37:06(UTC)
Nice work ber Yes
Originally Posted by: ioan92 Go to Quoted Post
In order to improve the practical usability of the slider, I propose, of course if it is possible, to include inside the object draw, labels for the current selected value and also for the minimum and the maximum values at least.
Hi Ioan,
it's not impossible, just a little bit annoying Good
I think that I can add both the solutions (current value and start/end values).
BTW in the preliminary "documentation stage" of this plugin, I've seen some sliders using primary ticks (with optional numbering) and secondary ticks (without numbering). This was discarded because the approach is completely different from that used in the standard .NET controls, so the SMath Viewer would have been a big tricky (with total rewriting of the default Control code)
Best regards,
Davide
Edited by user 14 March 2014 04:26:24(UTC)  | Reason: Not specified
on 14/03/2014(UTC)
#11 Posted : 18 March 2014 02:04:14(UTC)
UPDATED
(SMath Studio 0.97.5189)
- code updated to fit the new APIs features;
- settings with double-click over the region (as for the other control regions);
- hidden the outer frame (still remains as transparent to avoid interferences with resize markers).
#12 Posted : 22 March 2014 20:32:30(UTC)
UPDATED
- SMath Viewer: uses the region description (if exist and is shown).
on 22/03/2014(UTC)
#13 Posted : 09 April 2015 19:03:06(UTC)
PLUGIN UPDATED SMath Studio 0.97.5576 (08 April 2015)
- Fixed unintentional change of value on resize;
- Yesterday: Plugin updated to respect changes in SS Core;
- Yesterday: fixed MouseWheel vs recalculation;
- Yesterday: fixed +/- keys vs keyboard layout;
Edited by user 09 April 2015 20:40:45(UTC)  | Reason: Not specified
on 10/04/2015(UTC)
#14 Posted : 05 November 2015 22:04:12(UTC)
PLUGIN UPDATED SMath Studio 0.97.5737
- Introduced settings from canvas (see attachment);
- History Undo/Redo now is supported;
canvas settings.sm (23kb) downloaded 89 time(s).
Edited by user 06 November 2015 01:56:30(UTC)  | Reason: attachment updated
on 05/11/2015(UTC),  on 06/11/2015(UTC),  on 06/11/2015(UTC),  on 06/11/2015(UTC)
#15 Posted : 06 November 2015 02:06:25(UTC)
Hi Ioan Good
For practical use, I have two question:
1. "settings_numUpDown" is a dedicated unique name for parameters settings ?
You can define a different set of settings for each control in the worksheet, and you can use the name you want; I've changed the variable name in the attachment, to avoid misunderstandings.
2. for each of a set of controls, the "CustomVarName" used is the last one declared ?
The last definition before each single control is the only one parsed and loaded (if valid). If you override the variable between two controls which are linked to the same variable, the 2nd control will contains different settings than the first.
BTW I've updated both Slider and NumericUpDown regions, now the list of available settings is alphabetically sorted and subscripts in variable names are localization-proof.
Edited by user 06 November 2015 03:05:31(UTC)  | Reason: Not specified
on 06/11/2015(UTC)
#16 Posted : 08 November 2015 09:50:06(UTC)
"As for now, do not use this plugin for productivity."
____________________________________
Amazing: my Smath came with the slider, I played a bit and found useless
as not having the fractional range from script. Whether useless for me
is not my point. My point is that now it is gone from the insert menu.
How come it died by itself ? On the other hand, the Mathcad slider was
not recognised by PDF.
#17 Posted : 08 November 2015 14:46:42(UTC)
Hello Jean Good
I can remove this warning, the plugin is stable and I've not noticed requests of deep changes in the core features.
This is not possible. A clean installation (no SS available before or deep cleaning after an unistall) comes out with the plugins shown in the spoiler. If you have any other plugin it is because they were installed in a previous version of SMath Studio, manually downloaded from the Extensions Manager or downloaded by opening worksheets in which these plugins are used.
To provide compatibility with the Windows trackbar in SMath Viewer any value (max value, min value, increment, output value) must be an integer; to mitigate this limitation I've introduced a scale factor.
How come it died by itself?
You can see a document that contains this plugin without the "Slider" item in the insert menu? Huh
Edited by user 08 November 2015 14:48:58(UTC)  | Reason: Not specified
#18 Posted : 29 February 2016 01:52:59(UTC)
Hello Ioan,
As for now there aren't labels in this region, neither for the ticks nor for the current value.
The only way to display the value is to place a math region near the control.
BTW, fixed missing settings on save. PLUGIN UPDATED.
on 29/02/2016(UTC)
#19 Posted : 29 February 2016 18:55:30(UTC)
Possible it is possible, the effort is to made something consistant with the already implemented features (f.e. the vertical style)
I've updated the plugin adding a label for the current value (SMath Studio/SMath Viewer)
on 29/02/2016(UTC)
#20 Posted : 29 February 2016 19:43:51(UTC)
Hello Ioan,
the label should be visible by default on cursor changes.
Guest (2)
3 Pages123>
