SMath Studio Forum
Bugs & Problems
plot of an augment function with 'x'
Joined: 08/03/2012(UTC) Posts: 25 Location: Prague, Dolní Chabry Was thanked: 3 time(s) in 2 post(s)
augment x.sm (7kb) downloaded 30 time(s).Hello. It is not possible to plot an augment function with 'x' as parametr. Is it a bug, or some special feature of 'x'? regards Olik
This is not a bug. In the 2D plot region x and t are special unknowns (abscissa and animation parameter); both are parsed as local variables (doesn't matter if there are these variables on the canvas as defined values - except for t that can be used if you don't animate the plot). Therefore when you write augment(x,y) you are trying to augment each x displayed in the plot with y. Obviously you can define the input matrix before the plot, outside the region placeholder; in this case x and y are parsed outside the plot and the input is simply the 3x2 matrix. The X-Y plot works differently. Edited by user 20 May 2016 22:25:36(UTC)
| Reason: marked as solved |
In general, only lastError [this variable will be overwritten by any function giving an error.] and maybe i (there should be a post by Martin Kraska somewhere about issues noticed using i in some special case) and e.
SMath Studio Forum
Bugs & Problems
