SMath Studio Forum
Bugs & Problems
Ignore units or Error: Result is above max.allowed positive number
Hello community, with activated units the evaluation of a expression in my sheet is aborted with the error:"Result is above max.allowed positive number". If units for the sheet are deactivated the expression is evaluated, but the result is different. units deactivated:
Changing the evaluation to numeric does not change the behaviour - I followed the discussion here: Result-is-above-max-allowed-positive-number. Do you have general advice to resolve the issue of the aborred evaluation of the expression?If necessary I would send smath-file via Email (work in progress for a publication*). Bye radex Ps.: @community here - thank you for smath and all the great plugins *will late be published as a tutorial
Post the work sheet, that will help. on't use unit from the menu. Define separately, plug in the place holder.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,653 Location: Italy Was thanked: 1340 time(s) in 879 post(s)
Without the worksheet is really hard to understand where may be the issue... Originally Posted by: radex Do you have general advice to resolve the issue of the aborred evaluation of the expression? Have you tried to force a partial numeric evaluation in either the numerator or the denominator using eval(#)? Edited by user 21 May 2016 02:27:54(UTC)
SMath Studio Forum
Bugs & Problems
