Offline mikekaganski
#1 Posted : 30 March 2016 07:17:49(UTC)
mikekaganski
coolprop.sm (5kb) downloaded 30 time(s).
This file uses CoolProp wrapper plugin to get some water property.
But between two invocations, a calculation is made that changes some state, so that after it any CoolProp calculation fails.
May it be that A() somehow mangles, say, FPU state (flags)? Like exeption masking, or somesuch?
Edited by moderator 23 April 2016 12:10:08(UTC)  | Reason: marked as solved
Best regards,
Mike Kaganski
thanks 1 user thanked mikekaganski for this useful post.
on 02/04/2016(UTC)
#2 Posted : 31 March 2016 20:13:05(UTC)
Confirmed. Huh
#3 Posted : 01 April 2016 04:03:24(UTC)
I have a good idea about this plugin, having programmed WaterSteam in Visual basic
years ago. The plugin may be OK by itself but it suffers from the Smath silent
killer bug. Naturally, getting some properties uses some of the related constants.
Then, getting next properties does not renew constants previously used, and you get
any zombie result. Nothing to do untill this bug is cleared. The "clear" function
works, does not work.
If you work with WaterSteam, better get the freeware from "Katmar" [piece of gold].
Same formulation than IAPWS [quite monkey business inside IAPWS].
I programmed them in Mahcad 11, collab Fred was very happy.
on 02/04/2016(UTC)
#4 Posted : 01 April 2016 04:22:27(UTC)
Please don't reply: do this, do that
Smath does NOT do first, I don't have to do what it should do.
on 02/04/2016(UTC)
Offline Andrey Ivashov
#5 Posted : 01 April 2016 18:32:36(UTC)
Rank: Administration
Fixed in Stable SMath Studio 0.98.5935.
Thank you.
on 02/04/2016(UTC),  on 02/04/2016(UTC)
#6 Posted : 02 April 2016 00:56:42(UTC)
Jean, thank you for pointing out the different behavior of Clear about built-in constants. My fault, was in my knowledge and I've forget to document it.
I've updated the plugin (SS 0.97.5346 and later), now the description of Clear(...) reflects also this behavior.
Thank you.
Once again, thank you very much Andrey. Good
Edited by user 02 April 2016 01:00:41(UTC)  | Reason: Not specified
on 02/04/2016(UTC)
