Joined: 04/01/2014(UTC) Posts: 19 Location: Bern Was thanked: 14 time(s) in 12 post(s)
I have noticed the same Problem with the german version of SM :'(
Tinu
Andrey, You are right, "cic3-1.sm" works with the latest and greatest Maple plugin, that Uni updated few days ago. But I'm talking about the next bug. Please look at the worksheet in attachment. Regards, Igor example_that_works_in_5973.sm (8kb) downloaded 67 time(s).
1 user thanked tomtit for this useful post.
Hello Igor, I'm not sure about what you should have as a result. The attached works fine in version 5346. Works fine for what I would expect. Jean Maple coeffs NumDen.sm (30kb) downloaded 47 time(s).
Jean, Yes it does! But try any version > 5973.
Igor, my dear friend: I'm an ! irreducible 5346 ! like an "irreducible polynomial".
Originally Posted by: Tinu I have noticed the same Problem with the german version of SM :'(
Tinu Same in French... Maple Wrapper refuses to work, refuses to update, refuses to disable! But after turning to English, it works again.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,657 Location: Italy Was thanked: 1342 time(s) in 881 post(s)
It is a bug in localization handling of MapleWrapper about the function description in the dynamic assistance; current supported languages are ENG/RUS/UKR/BEL, an exception is fired when one different language is used in the maple() dictionary and the plugin fails to start. Viacheslav can fix it Edited by user 25 August 2016 10:30:21(UTC)
To clarify this bug, you must have the Maple version used by Smath. Up until now, the bug is wrt Smath 5346. Maybe Uni will catch that one. Jean ODE Laplace 2nd [Unexpected Bug].sm (38kb) downloaded 36 time(s).
Joined: 28/08/2014(UTC) Posts: 1,372 Was thanked: 834 time(s) in 528 post(s)
Originally Posted by: CBG You can not install the Maple plugin in Smath Studio , if Smath Studio is in Spanish.
If you put Smath Studio in English , then you can load the plugin Mapler , but when you changes again Smath Studio to Spanish and restarted, then the plugin will not start.
Carlos ¡Gracias! Parecía como si funcionara únicamente cuando le daba la gana. Best regards. Alvaro.
Estimado Alvaro.
Efectivamente el Programa no acepta el Plugin si Smath Studio esta en español. Si uno lo pone en Ingles, si carga Maple, pero al regresarlo al español, el plugin no arranca.
Parece que eso sucede también en otros idiomas.
Ya lo reporte también en la nueva versión.
Saludos
Joined: 23/03/2016(UTC) Posts: 278 Was thanked: 91 time(s) in 57 post(s)
Not sure if this is a maple wrapper issue but thought I would start here. I'm using the new version of SMATH (6081) and Version 1.0.6067.40150 of Maple Wrapper. When I use simplify, it converts a variable with 'I' to 'i'. See attached .sm file. Notice "I.BIAS" in the input and the "i.BIAS" at the output. example.sm (5kb) downloaded 70 time(s).Edited by user 26 August 2016 21:08:42(UTC)
"When I use simplify, it converts a variable with 'I' to 'i'. See attached .sm file. Notice "I.BIAS" in the input and the "i.BIAS" at the output. ________________________________
The greatest, often glorify themselves of the weirdest stupidity:
Mathematica imaginary 'i' is an horrible insane invented gyzma !!!! Maple is as stupid: the universal 'i or j' imaginary is 'I' Wise enough, it corected your input. It toke me days to elucidate. In Smath 5346 if above an indexed 'i' is part of a program AND IF 'i' is imaginary in an above definition the programme is all freaked but no error message. It was reported and AFAIK, has been corrected in newer versions.
Originally Posted by: Davide Carpi It is a bug in localization handling of MapleWrapper about the function description in the dynamic assistance; current supported languages are ENG/RUS/UKR/BEL, an exception is fired when one different language is used in the maple() dictionary and the plugin fails to start. Viacheslav can fix it Updated. Try now. |
Originally Posted by: tomtit Hello Uni, Thank you for your efforts of supporting Maple plug-in. But since Smath 5973, most of my worksheets failed to work. The next bug, hopefully is that the later Smath puts some "unwanted" placeholder for units into result of some symbolic calculations. The attached screenshot shows such a problem. If "t" was obtained as a result of calculation, the further symb. calculation failed, but if I assign "t:=" by copy-pasting the value stripped of the placeholder, it works ! It also possible that some trailing character is removed from the result string. Uni, could you please look into this issue ? Thanks and best regards. We have two functions numden() here (SMath Studio and maple). I think it is the reason. I'll try to fix this. Duplicate functions must be specially converted. Edited by user 31 August 2016 09:11:05(UTC)
Originally Posted by: arielyles Not sure if this is a maple wrapper issue but thought I would start here. I'm using the new version of SMATH (6081) and Version 1.0.6067.40150 of Maple Wrapper. When I use simplify, it converts a variable with 'I' to 'i'. See attached .sm file. Notice "I.BIAS" in the input and the "i.BIAS" at the output. example.sm (5kb) downloaded 70 time(s). Fixed and updated. Try now. |
3 users thanked uni for this useful post.
on 31/08/2016(UTC), on 31/08/2016(UTC), on 08/09/2016(UTC)
Originally Posted by: tomtit Andrey, You are right, "cic3-1.sm" works with the latest and greatest Maple plugin, that Uni updated few days ago. But I'm talking about the next bug. Please look at the worksheet in attachment. Regards, Igor example_that_works_in_5973.sm (8kb) downloaded 67 time(s). The problem is deeper than I thought. maple() function doesn't look recursively nested expressions. Because of this function names are intersecting (sum, product). Maple can't works with SMath functions and we have errors (expression transmitted as is). When we write a command on a single line - it works (maple( command_all_in_one )). If we use complex external expression, then we get an error. I think previously the function worked because the program has transformed the expression before passing it to the function. To support nested expressions, I need to further process the input expression. I need a time for this. |
"Example that works" ... YES but: 1. Not generalised enough. 2. Result is in reverse order. Jean Maple coeffs NumDen.sm (22kb) downloaded 33 time(s).
Hello ! Viacheslav ... while you are there, Can you examine the bug in the Laplace DE 2nd order. The bug is about Maple refusing the forcing function sqrt(t). Everything is explained in the work sheet. Jean ODE Laplace 2nd [Unexpected Bug].sm (16kb) downloaded 37 time(s).
Hello, Jean. If I understood correctly when we use q(t) := sqrt(t) we will get an error. In this case maple answer is too complex for SMath: Code:
4*y0*exp(-1/2*m*t)/(4*n-m^2)*n*cos(1/2*(4*n-m^2)^(1/2)*t)-y0*exp(-1/2*m*t)/(\
4*n-m^2)*m^2*cos(1/2*(4*n-m^2)^(1/2)*t)+y0*m*exp(-1/2*m*t)/(4*n-m^2)^(1/\
2)*sin(1/2*(4*n-m^2)^(1/2)*t)+2*y1*exp(-1/2*m*t)/(4*n-m^2)^(1/2)*sin(1/2\
*(4*n-m^2)^(1/2)*t)+1/2*Pi^(1/2)*int(4*_U1^(1/2)/Pi^(1/2)*exp(-1/2*m*(t-\
_U1))/(4*n-m^2)^(1/2)*sin(1/2*(4*n-m^2)^(1/2)*(t-_U1)),_U1 = 0 .. t)
We have int() function here in unexpected for SMath form. We can suppress integrals using NO_INT option but in this case Dirac() function appears which is defined in Statistical Tools plugin. Code:
-(y0*(-s-m)-y1-1/2*Pi^(1/2)/s^(3/2))/(s^2+s*m+n)*Dirac(s)
We have another error - "s - undefined" (Dirac() not defined for symbolic argument). |
Thanks Viacheslav,
You are 100% correct in few words, only an Smath limit access. Your first black snipet is identical to Mathcad 11, just differently presented. I may still have some sufficiently good approximation sqrt(x). Anyway: a pretty odd forcing function... most appreciated.
