Joined: 19/09/2009(UTC) Posts: 34 Was thanked: 17 time(s) in 11 post(s)
3 users thanked pdalet for this useful post.
on 31/07/2012(UTC), on 31/07/2012(UTC), on 17/10/2012(UTC)
Thank you Phillipe , The link to these packages could be put on the SMath download page as well, AFAIC Regards, Radovan omorr attached the following image(s): |
Joined: 21/08/2014(UTC) Posts: 18 Was thanked: 1 time(s) in 1 post(s)
Thank you for the deb version. I have some problem : Plugin don't install they fail each time. I tested if it wasn't a problem of rights but apparently not as they do it as sudoer too... Anybody tested it and got same problem or not Regards
Hello uni , Thank you for this *.deb file. As we can see from the first post, there were some other efforts here to make a *.deb file for SMath as well. Unfortunately, your *.deb version does not work for me on my Mint 17 64bit. It installed without complaints, but I just can not start it. There is no any messages, just silence . Regards, Radovan |
Tested on Ubuntu 16.04 x32. Try to input this command in the terminal: Code:$ mono /usr/share/SMathStudio/SMathStudio_Desktop.exe
Output must be similar to this: Code:uni@ubuntu:~$ mono /usr/share/SMathStudio/SMathStudio_Desktop.exe
WARNING: The runtime version supported by this application is unavailable.
Using default runtime: v4.0.30319
- [AppDir] Special Functions (1.11.6103.14494) [16 ms]
- [UserDir] Custom Functions (1.1.6100.11764) [25 ms]
- [UserDir] Maple Wrapper (1.0.6097.39410) [321 ms]
- [UserDir] X-Y Plot Region (Chart2DLib) (0.1.6018.34895) [32 ms]
- [UserDir] include (0.1.6097.39404) [16 ms]
- [UserDir] Memo Region (0.1.6092.16652) [11 ms]
- [AppDir] HTML Export (1.13.6103.14495) [1 ms]
- [AppDir] Export to image (1.9.6103.14499) [1 ms]
- [AppDir] Picture Region (1.10.6103.14497) [10 ms]
- [AppDir] Plot Region (1.9.6103.14499) [8 ms]
- [AppDir] SMath Studio Files Plugin (1.9.6103.14499) [1 ms]
- [AppDir] Text Region (1.10.6103.14497) [3 ms]
- [AppDir] SMath Viewer Files Plugin (1.1.6103.14500) [1 ms]
- [AppDir] XMCD Files Plugin (1.12.6103.14497) [3 ms]
Edited by user 24 September 2016 14:45:43(UTC)
I've tried on my home computer - Xubuntu 14.04 x32- and it complained about "bad" *.dbu file. I ignored that and it installed Ok. Unfortunately, it does not work for me as well. Just started, it complained about updating plugins and freezes. Anyway, I was intended to upgrade to Xubuntu 16.04 these days and we'll see than.
Regards, Radovan |
One more thing, in this package in the dependencies I didn't point to install mono (mono_runtime) as additional package. You must do it manually using this link before installing the deb. As Andrey wrote: " last version of Mono distributive required!". |
on 11/03/2017(UTC), on 11/03/2017(UTC)
smathstudio_0.98.6325_all.zip (952kb) downloaded 30 time(s).maple() restored but works too slow on mine machine. This is because the Wine is not properly configured I think. |
on 29/04/2017(UTC), on 01/05/2017(UTC)
smathstudio_0.98.6437_all.zip (961kb) downloaded 25 time(s).Quote:maple() works too slow on mine machine. This is because the Wine is not properly configured I think. |
on 06/03/2018(UTC), on 06/03/2018(UTC)
Hello, I use Smath studio for education purpose. I previously had it on debian strech were it works very well but now I switch to ubuntu 18.04 and I install it with the deb package.
The issue is I cannot see all the symbols in the toolbar. It's the symbol wich is Black over white in omorr screenshot.
Sombody have an idea? a dependencie missing?
