Joined: 19/03/2016(UTC) Posts: 8 Location: czech republic
I writing work on High School on topic IIR filtres and I need to create matrix of order 0.
In matlab: p_0_NDP = [] p_0 = Omega_n * p_0_NDP;
In SMath studio?
x:#clean# - does not work
Thank you for help.
ZeroMatrix: like this
Originally Posted by: Jean Giraud ZeroMatrix: like this But it is not. If I insert M(0) is length matrix 1, but I need length matrix 0
I don't believe SMath supports empty Matrices. |
Can you upload an example of what you're trying to accomplish?
We might be able to help implement it a different way. |
You can send e-mail adress on you? I need help about SMath studio functions. Thank you. Originally Posted by: arielyles Can you upload an example of what you're trying to accomplish?
Originally Posted by: smath_amaters But it is not. A matrix of order zero is a "zero matrix" If you want it rectangular from the fx menu 'Ones(3,5)' ,,,, then of any value: *1.23456789=
Example for declaration and use of an empty matrix: stack.sm (12kb) downloaded 27 time(s). |
Awesome. Thanks, Martin. I did not know that empty matrices were supported. |
... a more elegant way to "skin the cat".
... technical matrix
Originally Posted by: smath_amaters I need to create matrix of order 0 At this point, you know how to create a "zeromatrix". Visit "Samples => PseudoInverse" few days ago, This type of matrix: you fill-in manually. ===================================================== The other style matrices construct by themselves from their governing algorithm. Download the attached work sheet. I may be wrong but I would think your IIR filter is one of this type matrix that constructs around the IIR algorithm. Jean Spline l_p_c.sm (146kb) downloaded 30 time(s).
