2 Pages12>
Offline Ber7
#1 Posted : 08 December 2013 18:51:06(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
This method was suggested by the author of the "Method of Draghilev" prof. Alexei Ivanov.
1.st through the matrix of three columns (x, y, z) to construct
3d graph and select the desired Rakurs;
2.Using linear coordinate transformations turn
all points of the matrix at an angle (angles) corresponding
Rakurs and obtain a new matrix;
3. Out of three columns of the new matrix choose two and
substitute them in 2d graph;
Animation shows two first surface constructed A.Ivashev second
V.Mezentsev (Bottom). The animation is done on a flat graph.
Edited by user 21 October 2018 20:27:14(UTC)  | Reason: Not specified
File Attachment(s):
ButKlejn.smz (5kb) downloaded 135 time(s).
Tore1.smz (11kb) downloaded 165 time(s).
But1.smz (6kb) downloaded 157 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 08/12/2013(UTC)
Offline Ber7
#2 Posted : 28 December 2013 22:47:32(UTC)
Ber7
Israel
Updated.Fixed mistake in the first matrix coordinate transformation
on 31/01/2014(UTC)
Offline Ber7
#3 Posted : 16 January 2014 23:19:01(UTC)
Ber7
Israel
Animation spatial mechanisms
To calculate the position of the mechanism will use
techniques developed A.B.Ivanov.His work on 3d
animation mechanisms made ​​in Mapl, publishes A.B.Ivanov
online
http://forum.exponenta.ru/viewtopic.php?t=12842
Of the examples from this site I suffered in a programming environment SMath Studio
1. Sarrus linkage 1
Offline Ber7
#4 Posted : 30 January 2014 23:14:59(UTC)
Ber7
Israel
File Attachment(s):
TorSphere.smz (6kb) downloaded 132 time(s).
on 31/01/2014(UTC)
Offline Ber7
#5 Posted : 05 November 2014 19:35:17(UTC)
Ber7
Israel
Rotation around the coordinate axes
File Attachment(s):
ButKlejn.smz (7kb) downloaded 99 time(s).
on 05/11/2014(UTC)
Offline Ber7
#6 Posted : 02 February 2015 17:03:15(UTC)
Ber7
Israel
1.Torsion and bending Plate
2.Torsion and bending cylindrical panel
Using nonlinear coordinate transformations
Edited by user 07 March 2015 18:51:31(UTC)  | Reason: Not specified
File Attachment(s):
Panel.smz (6kb) downloaded 109 time(s).
Plate.smz (7kb) downloaded 122 time(s).
thanks 4 users thanked Ber7 for this useful post.
on 03/02/2015(UTC),  on 05/02/2015(UTC),  on 26/02/2016(UTC),  on 26/02/2016(UTC)
Offline Ber7
#7 Posted : 26 February 2016 12:57:04(UTC)
Ber7
Israel
Rotation About an Arbitrary Axis in Space
The algorithm is taken from the bookBiggrin. F. Rogers and J. A. Adams. Mathematical
Elements for Computer Graphics,second edition. McGraw-Hill Publishing Company,
1990,pages 121-127
Rotation2.smz (10kb) downloaded 84 time(s).
Edited by user 28 February 2016 17:36:31(UTC)  | Reason: Not specified
thanks 3 users thanked Ber7 for this useful post.
on 26/02/2016(UTC),  on 26/02/2016(UTC),  on 26/02/2016(UTC)
#8 Posted : 29 February 2016 00:17:42(UTC)
Rotation2.smz ,,,, does not work Smath 5346
egamma: not defined [does not evaluate]
ex, ey, ez don't evaluate ,,,
Smath 5346 does not recognise Rotatio2 coding.
Thanks for the other ones.
Offline Ber7
#9 Posted : 29 February 2016 03:30:29(UTC)
Ber7
Israel
For SMath 5890 file works fine. For SMath 5346 file can not verify.
Offline Ber7
#10 Posted : 15 November 2016 22:29:15(UTC)
Ber7
Israel
Building the surface deflection a Circular Plate for periodically applied load (Smath 0.98.5935)
Timoshenko.sm (390kb) downloaded 117 time(s).
on 16/11/2016(UTC)
#11 Posted : 16 November 2016 06:10:08(UTC)
Thanks: very nice. That's how you can tell the age of the lady !
Offline Ber7
#12 Posted : 23 February 2017 12:07:26(UTC)
Ber7
Israel
Tension,torsion and bending beams
Beams.smz (16kb) downloaded 82 time(s).
on 24/02/2017(UTC)
Offline Ber7
#13 Posted : 19 April 2017 10:46:02(UTC)
Ber7
Israel
Dome of Viviani Windows
The dome is made out of a variable number of Viviani curves generated by the intersection of the
hemisphere and the moving cylinder.A real-life application of this can be seen at the Osaka Maritime Museum
https://en.wikipedia.org...ki/Osaka_Maritime_Museum
V4.sm (24kb) downloaded 66 time(s).
on 19/04/2017(UTC),  on 19/04/2017(UTC),  on 24/04/2017(UTC)
Offline Ber7
#14 Posted : 23 April 2017 12:24:49(UTC)
Ber7
Israel
Gateshead Millennium Bridge
http://en.wikipedia.org/...eshead_Millennium_Bridge
The arch and the bridge deck can be rotated together around large bearings, lifting the bridge deck to let small ships and boats pass underneath. This is the essential idea behind the Gateshead Millennium Bridge, a pedestrian and cyclist tilt bridge. It spans the River Tyne in England between Gateshead on the south bank and Newcastle upon Tyne on the north bank.
Most.sm (35kb) downloaded 58 time(s).
on 24/04/2017(UTC)
Offline Ber7
#15 Posted : 26 April 2017 16:00:02(UTC)
Ber7
Israel
Continuation. The principle of operation of the bridge
Most.sm (35kb) downloaded 57 time(s).
Edited by user 27 April 2017 08:03:33(UTC)  | Reason: Not specified
on 26/04/2017(UTC),  on 26/04/2017(UTC),  on 27/04/2017(UTC),  on 27/04/2017(UTC)
Offline Ber7
#16 Posted : 05 June 2017 14:04:06(UTC)
Ber7
Israel
Beam of rectangular section. Very simple code.
Section.sm (18kb) downloaded 88 time(s).
on 05/06/2017(UTC),  on 06/06/2017(UTC),  on 10/10/2017(UTC)
#17 Posted : 05 June 2017 20:09:00(UTC)
Thanks Ber7,
I love those things that move, but they dilute my "winter chicken brain" !!!
You may want to roll the torus. Very nice in Mathcad, unfortunately, can't
attach the animation because XP Pro. does not support any of the Mathcad "Codecs".
Torus.sm (156kb) downloaded 52 time(s).
Offline Ber7
#18 Posted : 08 October 2017 22:39:32(UTC)
Ber7
Israel
Rotation around an arbitrary axis defined by two points.Continuation
https://en.smath.info/forum/yaf_...-B-Ivanov.aspx#post30728
Rotation3.sm (36kb) downloaded 58 time(s).
on 10/10/2017(UTC)
Offline Ber7
#19 Posted : 09 April 2018 21:42:55(UTC)
Ber7
Israel
Updated
Rotation4.sm (28kb) downloaded 51 time(s).
on 10/04/2018(UTC)
Offline Ber7
#20 Posted : 05 June 2018 18:31:28(UTC)
Ber7
Israel
The spiral curved along a given 3d curve
Spiral1.sm (22kb) downloaded 47 time(s).
Spiral4.sm (21kb) downloaded 46 time(s).
Spiral5.sm (20kb) downloaded 44 time(s).
Edited by user 04 May 2022 10:33:38(UTC)  | Reason: Not specified
on 05/05/2020(UTC)
Guest (2)
2 Pages12>
