#1 Posted : 29 July 2017 01:05:44(UTC)
I am trying to solve the problem that I can't overwrite special functions in the Maxima plugin via the IPluginLowLevelEvaluation.ExpressionEvaluation interface, see SS-2401.
Obviously one can add definitions to the canvas from within a plugin function execution using something like this:
Code:
Entry lhs = Entry.Create(TermsConverter.ToTerms("int(f,x,a,b)"));
Entry rhs = Entry.Create(TermsConverter.ToTerms("Int(f,x,a,b)")); ;
Entry def = context.AddDefinition(lhs, rhs);
This replaces the built-in definition of int(4) with the one provided by the maxima plugin in the current downstream canvas.
The above solution was found by blindly poking around, assisted by the Core doc.
Questions:
- Can I generate the definition directly from the text representations?
- How can I remove the definition?
- It seems that the variable names used in the definitions matter. int() does not provide the same results as Int() in some cases.
- What plugin might be a good source of inspiration for the above questions?
#2 Posted : 29 July 2017 01:36:19(UTC)
Good trick Good
You can split a plain text representation at the first definition symbol and generate the LHS & RHS parts; (C# string.Split() methods);
Store.RemoveAt(), Store.removeRange() and Store.Clear() are the methods (last if you know the Definition, first two if you record where they were placed;
I have to check.
probably the include plugin by Viacheslav
on 29/07/2017(UTC)
#3 Posted : 29 July 2017 02:32:40(UTC)
Possible code:
Code:
int index = context.Count;
try
  // do your stuff here
catch
  // errors, they might happens
finally
  // remove the definition, even if an error occourred
  context.RemoveAt(index);
#4 Posted : 29 July 2017 15:54:59(UTC)
Thanks, Davide.
The include plugin has just one occurance of AddDefinition.
The idea is now to obtain the index of the definition using Store.Contains(Entry,Index) and remove it with RemoveAt()
As to the dependence on variable names: It was mitigated by also doing preprocessing for the integration variable in Int(4), otherwise parameter replacement didn't seem to work. Usually, the integration variable is just a dummy name and should not require preprocessing...
Is it sensible to use strange variable names like x__ in the definitions as it is sometimes on the canvas?
#5 Posted : 29 July 2017 18:47:22(UTC)
Personally, I like the way it was 5346 still 6179 latest release.
#6 Posted : 30 July 2017 02:52:21(UTC)
I implemented a new MaximaTakeover() function, which adds definitions to the context or removes them according to the given arguments. First tests seem very promising, such that the full functionality of the Maxima plugin can be re-established soon.
It turned out that something like
Code:
int index;
if (context.Contains(lhs, out index) context.RemoveAt(index);
didn't do the job of deleting the definitions from the global context. The deletion actually worked (as per inspection in the debugger) but that was of only local scope. I had to resort to Clear().
Code:
        public static bool MaximaTakeoverF1(Term[][] args, ref Store context, ref Term[] result)
            // List of available definitions
            String[] Functions = new String[]
                "Diff(f__)",
                "Diff(f__,x__)",
                "Diff(f__,x__,n__)",
                "Int(f__,x__)",
                "Int(f__,x__,a__,b__)",
                "Lim(f__,x__,x0__)",
                "Sum(f__,var__,a__,b__)",
                "Det(m__)"
            // Try to ensure maxima is running
            ControlObjects.CommunicationInterface.GetMaxima();
            // Check if Maxima is running and complain otherwise
            if (ControlObjects.CommunicationInterface.GetMaxima().GetState() != ControlObjects.CommunicationInterface.GetMaxima().GetMaximaStateRunning())
                result = TermsConverter.ToTerms(ControlObjects.CommunicationInterface.GetMaxima().GetState());
                return true;
            // normalize the arguments list to the first three characters of the string representation
            // i.e. int, dif, lim,...
            List<string> NormArgs = new List<string>() { };
            foreach (Term[] arg in args)
                string Arg = TermsConverter.ToString(arg);
                if (Arg.Length > 3) NormArgs.Add(Arg.Substring(1,3));
            // Loop over the available functions
            string message = "";
            foreach (String Function in Functions)
                string LhsString = Function.ToLower();
                Entry lhs = Entry.Create(TermsConverter.ToTerms(LhsString));
                if (NormArgs.Contains(LhsString.Substring(0, 3)) || NormArgs.Contains("all"))
                    // add definition
                    Entry rhs = Entry.Create(TermsConverter.ToTerms(Function)); ;
                    // augment message
                    string MsgPart = LhsString.Split('(')[0] + "(), ";
                    if (!message.Contains(MsgPart)) message += MsgPart;
                else
                    // remove definition
                    context.Clear(lhs);
            // Make result string
            result = TermsConverter.ToTerms(Symbols.StringChar + message + Symbols.StringChar);
            return true;
#7 Posted : 30 July 2017 03:19:33(UTC)
I like it this way...
Don't know, however, if it is safe to remove the ugly underscores from the variable names...
#8 Posted : 31 July 2017 19:08:43(UTC)
Hello Martin,
Interesting, though the algo style is native in Smath 5346, 6179
except the first release 6179 is missing Int(2) [indefinite].
I think Sum will work as well, at least it was 5346.
Cheers, Jean
Maths Algo Style [Diff, Int].sm (16kb) downloaded 13 time(s).
#9 Posted : 01 August 2017 17:26:43(UTC)
I'd like to provide a standard description to the definitions created in MaximaTakeover().
Currently, the descriptions simply show the definition (as can be seen in the previous post).
The idea is, to get the description of the Maxima function (Int(...) and add it as description to the generated definitions, perhaps with some adjustments (convert uppercase to lowercase in function names).
How would I do that?
Code:
        public static bool MaximaTakeoverF(Term[][] args, ref Store context, ref Term[] result)
                "Diff(f__)",
                "Diff(f__,x__)",
                "Int(f__,x__)",
                "Det(m__)"
                return true;
            // Generate a string with all args concatenated
            var ArgString = "";
            foreach (Term[] arg in args) ArgString = ArgString + TermsConverter.ToString((Decision.Preprocessing(arg, ref context)));
                if (ArgString.Contains(LhsString.Substring(0, 3)) || ArgString.Contains("all"))
                    // add definition
                    // augment message
                else
                    context.Clear(lhs);
            if (message.Length == 0) message = "All functions handled by SMath";
            else message = message.Substring(0, message.Length - 2) + " handled by Maxima";
            return true;
#10 Posted : 01 August 2017 20:23:20(UTC)
You can use the AddDefinition(Definition value) method; Definition has some constructor with the description argument
Edited by user 01 August 2017 20:27:58(UTC)  | Reason: Not specified
on 02/08/2017(UTC)
#11 Posted : 02 August 2017 02:06:09(UTC)
Thanks. Davide.
First, I tried a very compact way, but that didn't make it beyond the current math region.
Code:
                    // add definition
                    // add description
                    context[context.Count-1].Description =  "description of "+ LhsString ;
Then I used the approach proposed by you, unfortunately, the definition constructor requires a terms list to specify the arguments. I found no smart way to extract this list from the function definition strings. Thus the code looks ugly and bloated.
Code:
                    string name = LhsString.Split('(')[0];
                    string[] vars = Regex.Replace(LhsString, @".+\((.+)\)", "$1").Split(',');
                    Term[] Tvars = new Term[1];
                    int i = 0;
                    foreach (string v in vars)
                        Tvars[i] = new Term(v, TermType.Operand, 0); i++;
                    context.AddDefinition(new Definition(name, Tvars, rhs, "description of "+name));
This approach didn't work either, I even could not see the descriptions being generated at all in the debugger.
And in the end, when trying to provide a description in a math region directly, this is ignored. For the moment I have to give up. This might be related to the target functions being special functions. Re-definition somehow slips through, re-description obviously not.
#12 Posted : 02 August 2017 10:53:58(UTC)
Hello Martin,
Confirmed. I've looked at the core code and I know why, I'll try to make ii possible.
#13 Posted : 02 August 2017 13:26:29(UTC)
Sounds promising. There is more to report.
Code:
This guy isn't just useless, it is also dangerous. It sweeps all but one signature variants for each function off the context. Just the versions with a single argument survive this seemingly harmless line of code.
BTW, working with the debugger and observing how the context changes during function calls provides great insight into how SMath works. It's real fun!
