Joined: 05/10/2016(UTC) Posts: 22 Was thanked: 2 time(s) in 2 post(s)
Dear all, I am currently struggling with a basic function extreme problem NOK.sm (16kb) downloaded 27 time(s). OK.sm (61kb) downloaded 31 time(s).edit by mod: names of attachments are swapped, as mentioned belowIn the first screenshot, the function derivative definition results in a warning message: "input string was not in a correct format" In the last screenshot, I removed all parameters values that aren't related to the given formulas (not visible in the screenshot), and I get the right solution?! However, I don't see the root visually in the accompanying graph? I thought it had something to do with the reservation of parameter "x", but this doesn't seem to be the case... Thanks in advance for any feedback! Kind regards from Belgium, Jan Edited by moderator 26 August 2017 13:16:56(UTC)
| Reason: added BTS ID
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1124 time(s) in 721 post(s)
could you please attach the worksheet? |
Hello Martin,
Thank you for your fast reply, I just added the files...
Originally Posted by: janclaeys I don't see the root visually in the accompanying graph? ============================== The root(s) won't appear by magic ! You must instruct the plot. Click left/right on the 2nd plot ... enable "Display input data" Welcome to Smath Community, Jean Maths Golden Ratio jmG.sm (22kb) downloaded 19 time(s).
Hello Jean,
What I meant was that the derivative graph doesn't cross the X-axis at x=3.29, this is where the original function P_c_hor(x) reaches it's maximum. This is odd, since the root function indicates correctly a root at x=3.29 in the file NOK.sm (I switched the names the smath files, my mistake... ).
So my question remains: why does the solve function doesn't work in both attached files?
Kind regards,
Jan
Originally Posted by: janclaeys So my question remains: why does the solve function doesn't work in both attached files? ====================================== Hey mon ami ! You have not attached any file . Click on "Post reply" down the page. You will see the icon line, click on the paper clip "Insert an existing Attachment or upload a new file" Browse for the file in your system, double click on the file name You can add as many file as you wish [the limit is ~ 5 MB] Jean
True, I added them afterwards to my first message ;-) FYI: I switched the names of the files, my mistake...
You'll see what I mean if you compare the files. I used the last beta version of smath.
It could probably be repaired by zapping the entire system. Wait for Martin to check.
Ok, what do you mean with zapping? Debugging? Re-compiling the source code? Thanks for your feedback!
... as it looks, the derivative as given is not accepted. The mouse had problem digesting the elephant . Done from infinitesimal analysis ... OK. Maybe I open the wrong sheet ? Jean OK repaired.sm (64kb) downloaded 18 time(s).
Good evening Jean, No, you edited the right sheet ;-) (nok is ok and vice versa, I was too fast when I changed the filenames... ) Thank you for the work you put into this, I really appreciate this! As far as I can see, the problem seems to be (amongst others?) the use of units, since you removed every unit? I am aware that good old Mathcad (when it still belonged to Mathsoft, PTC made a mess of it...) also struggled with this. However, it stays unclear why my approach works in sheet "nok.sm" and not in "ok.sm", while it's 100% the same in both cases?! There seems to be something wrong underneath the smath "boot"? I will study the sheet more in detail (and put every value into SI) tomorrow at my work, thanks again! Kind regards, Jan p.s. As a BD (bande dessinée) fan, your name reminded me of this legend (aka Moebius) ;-) https://en.wikipedia.org/wiki/Jean_GiraudEdited by user 17 August 2017 00:30:35(UTC)
Originally Posted by: janclaeys However, it stays unclear why my approach works in sheet "nok.sm" and not in "ok.sm", while it's 100% the same in both cases?! There seems to be something wrong underneath the smath "boot"? ======================================== Can't explain either. NO unit plots much smaller in magnitude and the function q(x) ends @ 3.5. Infinitesimal analysis is a Lagrangian method that existed before "Symbolic engines". Was effective for Excel to manage more advanced maths before Mathcad/Mathsoft... Maple. It applies to 2nd derivative as well and integral. The 2nd derivative starts producing noise [world is not perfect]. The Lagrangian methods extend to point derivatives/integral ... very useful for point capture systems like in Process Control & Instrumentation where have only values [accumulated values]. In the red, in the attached, I have isolated the Guilty ... Ah ! As it looks, with the unit system those "Guilty" may be smaller, thus less guilty. Cheers, Jean OK repaired.sm (145kb) downloaded 16 time(s).
Hello Jean,
I made a revised version of my original document today, based on your remarks. Luckily, I managed to keep the units "on board": by doing so the document is more readable for my colleagues. Every value is correctly evaluated now: yes! Thank you for the hint about the infinitesimal derivative, let's hope that SMath's next version will have a flawless standard derivative function, since the actual one doesn't seem to work...
Kind regards,
Jan
Jan,
Please attach the document ... there may be ways to doctor your derivative ? In Smath, the derivative is strictly symbolic from the rules. Often, the rules are chained to deeply + limits in numerical evaluation. Glad you rescued the unit system. Attach just the working essentials.
Originally Posted by: Jean Giraud Jan,
Please attach the document ... there may be ways to doctor your derivative ? In Smath, the derivative is strictly symbolic from the rules. Often, the rules are chained to deeply limits in numerical evaluation. Glad you rescued the unit system. Attach just the working essentials.
Jean =============================== Here is a good example the derivative operator fails but rescued from the incremental derivative. Jean Maths Special Polylog Application.sm (22kb) downloaded 16 time(s).
Here the resulting file Solution.sm (104kb) downloaded 15 time(s).
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Hello Davide,
I run the latest beta (build 6437), and f(2) on the last page of "ok.sm" doesn't result in an answer (the standard smath derivative function doesn't work)? I run Windows 7 Pro. "nok.sm" does work, the reason for this is unclear because exactly the same formulas are used, however the graph doesn't show the correct shape of the derivative function.
It would be very strange if your configuration would be errorless? There has to be a program mistake somewhere?
Kind regards,
Jan
Originally Posted by: janclaeys Here the resulting file ================================= * no units are used here to facilitate the "solve" command In the definition of f(x) for the incremental derivative, the units in num/den do match and f(x) is pure unitless, just function of "x". The way you have it works fine. The curiosity is that if we isolate/export the symbolic expansion of f(x) ... the system fails ... damned puzzling ! Jean Solution Isolate_Fails.sm (23kb) downloaded 15 time(s).
Originally Posted by: janclaeys It would be very strange if your configuration would be errorless? There has to be a program mistake somewhere? It is strange indeed. Can you confirm that the error display on the uploaded file for you (download > open > error is shown; I mean, there were no issues while choosing the file to upload) I run the same version as your, on Win7 home. It might be something related to some plugin (to check it you can rename your %APPDATA%\smath folder into something different, then you can load a new instance of SS studio and check if something is changed) or might be something else, I'll try to see if I can found a way to replicate it at least find the cause for that error message. |
