SMath Studio Forum
Questions
[Dev] How to convert Term[] to Entry
Hi, how can I convert a terms list to an entry structure? The core doc says there is a function SMath.Manager.TryFixStructure, which unfortunately doesn't seem to be available in 0.98.6398.
I also failed to find a function to convert expression strings to Entry.
Thanky you for any hint. |
You can use the static method Entry.Create(IEnumerable<Term> value) Code:Entry myEntry = Entry.Crate(myTermsArray);
Thanks, Davide,
Seems that I asked the wrong question, I misunderstood an VS error message. It was about the result type, not of the argument type of Decision.NumericCalculation. I need to see how to handle TNumber objects.
BTW, if I want to move towards Entry instead of Term[] in the function arguments, do I need to do that everywhere at once or can I do that that step by step without breaking the whole plugin?
Martin |
Originally Posted by: mkraska Seems that I asked the wrong question, I misunderstood an VS error message. It was about the result type, not of the argument type of Decision.NumericCalculation. I need to see how to handle TNumber objects. Numeric library makes really easy to handle TNumbers... some examples here (see f.e. fft2) and here (logic starts from line 360) (I'll look if I can post something compact and complete later tonight) Originally Posted by: mkraska BTW, if I want to move towards Entry instead of Term[] in the function arguments, do I need to do that everywhere at once or can I do that that step by step without breaking the whole plugin? Absolutely, you can start implementing the IPluginLowLevelEvaluationFast instead of the IPluginLowLevelEvaluation, and convert Entry to Terms[] from where you don't are yet arrived in refactoring. |
SMath Studio Forum
Questions
