3 Pages123>
Offline oscampo
#1 Posted : 29 May 2012 23:14:49(UTC)
oscampo
Colombia
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expresed in F(s) form.
enjoy
numerical inverse Laplace Transform
Download it here
Oscar Campo
thanks 3 users thanked oscampo for this useful post.
on 30/05/2012(UTC),  on 30/05/2012(UTC),  on 30/05/2012(UTC)
Offline omorr
#2 Posted : 30 May 2012 10:09:26(UTC)
omorr
Rank: Administration
Serbia
Hello Oscar,
Thank you for this example Good
By the way, I find very interesting that you defined an expression in this way an then plot it:
Function<->variable
ft() looks like a function, but it is not.
on 30/05/2012(UTC)
Offline oscampo
#3 Posted : 30 May 2012 14:10:43(UTC)
oscampo
Colombia
Yes, it's something that I found accidentally. The statement ft(F(s)) appear as a function, but it's a matrix!
Oscar
Offline Basile
#4 Posted : 30 May 2012 22:18:43(UTC)
Basile
I tried to open it using the latest SMath.
I get an error message in the last FOR loop: "Function not defined"
Thanks,
Basile
Offline Andrey Ivashov
#5 Posted : 30 May 2012 22:53:17(UTC)
Basile Offline , you need to define a function to work with as shown in the first message.
Regards.
Offline Basile
#6 Posted : 01 June 2012 04:25:59(UTC)
Basile
Thank you Andrey,
Basile
Offline Basile
#7 Posted : 01 June 2012 04:28:48(UTC)
Basile
Oscar,
Which Numerical Inverse Laplace Transform do you use?
Any reference?
Thank you,
Basile
Offline oscampo
#8 Posted : 01 June 2012 16:24:33(UTC)
oscampo
Colombia
Hi Basile,
The method is based on work of J. Valsa and L. Brancik: Approximate Formulae for Numerical Inversion of Laplace Transforms, Int. Journal of Numerical Modelling: Electronic Networks, Devices and Fields, Vol. 11, (1998), pp. 153-166
Oscar
thanks 1 user thanked oscampo for this useful post.
on 01/06/2012(UTC)
Offline Basile
#9 Posted : 02 June 2012 00:29:58(UTC)
Basile
Oscar,
Thank you,
Basile
Offline oscampo
#10 Posted : 05 June 2012 02:47:33(UTC)
oscampo
Colombia
Bode Diagram Revisited.
This is a function for graphing the Bode plot of a system. Please plot the magnitude and phase on a diferent graph each one, deactivate "grid" and "axis" for a better visualization of logarithmic grid.
Bode Plot
Download it here
Edited by user 25 November 2019 18:33:45(UTC)  | Reason: links updated
Offline oscampo
#11 Posted : 05 June 2012 22:02:37(UTC)
oscampo
Colombia
Root Locus Snippet
This is a snippet for plotting Root Locus of a sistem. The input is the denominator of coefficients of transfer function:
rlocus
Download it here
Oscar
Edited by user 25 November 2019 18:37:55(UTC)  | Reason: links updated
Offline Leandro de Oliveira
#12 Posted : 25 August 2017 19:22:41(UTC)
Leandro de Oliveira
Brazil
The file seems to be locked, I can't put a equation.
#13 Posted : 25 August 2017 23:02:19(UTC)
.. here is the Bode Plot.
Bode plot.sm (28kb) downloaded 151 time(s).
thanks 2 users thanked Jean Giraud for this useful post.
on 27/08/2017(UTC),  on 16/11/2017(UTC)
#14 Posted : 26 August 2017 00:44:35(UTC)
Open the file in SMath Studio and then go to File > Properties > File Attributes and uncheck Read-only. This attribute is required when the worksheet is designed to be a snippet.
#15 Posted : 26 August 2017 15:01:49(UTC)
Hi, this is a snippet for numerical inverse Laplace transform. You can find time response of a system expressed in F(s) form. enjoy
This 5 years old document does not work 6179.
Here is the Maple companion.
Offline oscampo
#16 Posted : 27 August 2017 16:46:55(UTC)
oscampo
Colombia
Only a very little detail to fix this 5 years old document: declare F(s) and change the last line on snippet:
ft( "F(s" ) = augment(t,ft)
for
ft() = augment(t,ft)
You can download the updated version from here
Edited by moderator 28 August 2017 19:27:40(UTC)  | Reason: edited dropbox link to direct download
on 28/08/2017(UTC)
#17 Posted : 28 August 2017 17:01:53(UTC)
... that's only several pages long of HTML code.
No work sheet. Best is to upload WS in the forum.
For "Laplace stuff", better use maple(,) as show above.
Cheers, Jean
Offline oscampo
#18 Posted : 28 August 2017 17:32:53(UTC)
oscampo
Colombia
Use "save as"
Yes, and also it’s possible use f(t)=Maxima(ilt(F(s),s,t)) but it’s interesting show how you can implement inverse Laplace of a function in SMath.
P.D. The symbolic form of f(t) obtained from ilt() it’s more “elegant” than maple version Wink
on 28/08/2017(UTC)
#19 Posted : 28 August 2017 19:04:34(UTC)
Win 7 does not have the virtue to save HTML "save as" *.sm
OK: no work sheet => nothing to see. Tanks anyway.
Cheers, Jean
#20 Posted : 28 August 2017 19:24:42(UTC)
You can if you use firefox (with chrome you have to change the extension manually from .txt to .sm);
However I've edited the link, now it downloads the file, whatever is your favorite browser. Whistle
Edited by user 28 August 2017 19:26:58(UTC)  | Reason: Not specified
on 28/08/2017(UTC)
Guest (2)
3 Pages123>
