Joined: 19/01/2016(UTC) Posts: 6 Location: Livorno Was thanked: 9 time(s) in 4 post(s)
Hello I attach here a worksheet for the FEM analysis of 2D trusses, it has to be tested! Truss FEM.sm (329kb) downloaded 128 time(s).
1 user thanked LORENZO for this useful post.
I have no competence for testing, just that the nesting may be done more visually. Truss FEM otherwise.sm (20kb) downloaded 81 time(s).
Joined: 10/12/2009(UTC) Posts: 247 Location: Cali, Colombia Was thanked: 87 time(s) in 66 post(s)
Hi LORENZO, Here is FEMTRuss, my own version of truss calculus via FEM. I'll check your work, please you check mine FEMTruss.sm (50kb) downloaded 115 time(s).
Joined: 03/02/2014(UTC) Posts: 67 Was thanked: 13 time(s) in 11 post(s)
So far results look good. Great work!
The only thing I understand in there is the construction. Lovely labels, thanks ... a little detail In plotG, the symbol "." of size 14 is a beautiful little exact square from an old tip. Utilities XY [Draw Truss Labels].sm (20kb) downloaded 63 time(s).
Originally Posted by: Jean Giraud The only thing I understand in there is the construction. A little example solved by FEM... P4-118 Pytel modified.sm (166kb) downloaded 4 time(s).Edited by user 08 August 2023 21:14:46(UTC)
| Reason: Updated file to be compatible with new SMath version
