Is posssible to change answer number format?
example from 2*10^2 to 200 etc?
P.S. Thank You for Yours reponses it helps very much learning SMath.
Originally Posted by: Paulius Is posssible to change answer number format?
example from 2*10^2 to 200 etc? Please give more from your source, attach work sheet will help. Cheers, Jean
did you check "Exponential threshold" ?
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1126 time(s) in 723 post(s)
Section operation results formatting.sm (26kb) downloaded 75 time(s).This is page SMath Studio Documents> Display Control (Results Formatting) in the interactive handbook (you can find it in the extension manager) |
