7 Pages«<23456>»
Offline Alex M.
#61 Posted : 15 October 2016 01:55:41(UTC)
Alex M.
Good Day Davide,
I have used the "Field" functionality for a while now, in particular the "date" and the "worksheet info".
I have noticed that:
1. worksheet info field does not change if the actual smath file properties change
2. date changes the moment smath worksheets is re-opened
Is there a particulat reason for this behaviour? If you consider my suggestion worthwhile I propose to update the worksheet info fields every time the .sm file is opened to scan for changes. Also I propose to update the "date" field only when it is created or copied/cloned elsewhere - it would make sense to track the date when a particular calculation page in a .sm worksheet was created, not the current date/time at the instance of .sm file access.
A.M.
Edited by user 15 October 2016 02:04:53(UTC)  | Reason: Not specified
#62 Posted : 16 October 2016 18:58:06(UTC)
Hello Alex,
Yes, this is because the region is designed to have a low footprint and there isn't an event "File Properties Changed" for the worksheet; but I see that it doesn't changes even on file opening nor for region paste; I'll investigate it ASAP.
I suppose is matter of my habits; if I need a static date/time I write it directly or I convert the field to static text. However I realize that one might want it "less dynamic". What if I add a property for each field to drive the update? (whenever possible or just manual by context menu).
Edited by user 16 October 2016 19:05:58(UTC)  | Reason: Not specified
on 17/10/2016(UTC)
Offline Alex M.
#63 Posted : 17 October 2016 19:06:03(UTC)
Alex M.
Originally Posted by: Davide Carpi Go to Quoted Post
Hello Alex,
Thank you, Davide, both tweaks will be very much welcome, if and when you have time, of course.
thanks 1 user thanked Alex M. for this useful post.
on 18/10/2016(UTC)
#64 Posted : 02 November 2016 20:57:10(UTC)
PLUGIN UPDATED SMath Studio 0.98.5935 and later
  • Rendering logic refactored to be much more fast (smooth worksheet's scroll on huge regions or even on multiple regions intersecting the viewport);
  • Applied correction on characters' spacing to make them closer to common text editors;
  • Fields: added option to disable automatic updates;
  • Fields: fixed Worksheet's metadata not updated on file open/region paste;
  • Spell checker import tool: dictionary packages now are loaded directly (no needs to unpack them);
  • minor fixes;
  • refactoring;
  • documentation updated;
Edited by user 02 November 2016 21:16:41(UTC)  | Reason: Not specified
thanks 3 users thanked Davide Carpi for this useful post.
on 02/11/2016(UTC),  on 02/11/2016(UTC),  on 04/12/2016(UTC)
#65 Posted : 12 January 2017 18:12:34(UTC)
PLUGIN UPDATED SMath Studio 0.98.6179 and later Beta
  • fixed performances issues on print preview;
  • added overline style (CTRL+SHIFT+O);
  • fixed text color change vs fields;
  • minor fixes;
  • refactoring;
on 12/01/2017(UTC),  on 12/01/2017(UTC),  on 13/01/2017(UTC)
Offline ElSid
#66 Posted : 03 March 2017 22:41:07(UTC)
ElSid
United States
Davide,
Under version 0.98 build 6179 (64 bit) loaded, this plugin does not work as it used to. It used to be that CTR+Shift+W would pop open a "formatting" dialog box (per post #2 "floating toolbar"Wink like the text region utilities. Now it just opens a "text box which is the width of the sheet, but no formatting utilities. Is this because 64 bit loaded up when I upgraded?
PS Same issue with portable version I created with previous version. Can shis toolbar be placed in the side panel with the math/symbols, etc.?
PPS If I left mouse click and go to settings, the floating toolbar pops up. Is there a way to make this the default? (both desktop and portable)
Edited by user 03 March 2017 22:56:23(UTC)  | Reason: Not specified
#67 Posted : 04 March 2017 02:55:19(UTC)
Originally Posted by: ElSid Go to Quoted Post
Davide,
Under version 0.98 build 6179 (64 bit) loaded, this plugin does not work as it used to. It used to be that CTR+Shift+W would pop open a "formatting" dialog box (per post #2 "floating toolbar") like the text region utilities. Now it just opens a "text box which is the width of the sheet, but no formatting utilities. Is this because 64 bit loaded up when I upgraded?
Really strange Umnik
Only cases in which you should notice changes are on cleaning of settings folder (but this will load the default settings, that aren't the ones listed by you) or by your choice. Please check your settings in the "More..." > "Options..." menu ("New regions" and "Environment" tabs). Settings should be saved once you click on "OK" and never change, except in cases mentioned previously.
Nope. Since next SS relase should be possible to create plug-ins to have more toolboxes, but this won't be the place for Writer Region toolbars.
Edited by user 04 March 2017 03:31:56(UTC)  | Reason: Not specified
on 04/03/2017(UTC)
#68 Posted : 08 March 2017 14:13:00(UTC)
  • [critical] Fixed blue bleeding worksheet on history UnDo after deleting regions;
  • [critical] Fixed regions saved as empty when data pasted on canvas and no more edited;
Edited by user 08 March 2017 14:15:37(UTC)  | Reason: Not specified
on 08/03/2017(UTC),  on 08/03/2017(UTC)
#69 Posted : 08 March 2017 15:36:53(UTC)
My procedure Win 7, micro laptop:
1. from the insert menu => click the W symbol [insert writer region]
2. the empty rectangle appears [|]
3. click right for the drop down menu => click left "settings"
4. as you start typing in the rectangle the movable tool bar is active.
Offline Alex M.
#70 Posted : 08 March 2017 17:28:07(UTC)
Alex M.
Thank you for a prompt fix, Davide.
on 09/03/2017(UTC)
Offline ElSid
#71 Posted : 17 March 2017 16:57:52(UTC)
ElSid
United States
Jean,
That is the problem! The movable tool bar is active only after doing all that. It used to pop up @ step #1.
#72 Posted : 17 March 2017 17:21:16(UTC)
Have you tried to change your settings?
Edited by user 17 March 2017 17:22:54(UTC)  | Reason: Not specified
on 17/03/2017(UTC)
Offline ElSid
#73 Posted : 17 March 2017 18:29:35(UTC)
ElSid
United States
Environmental --> Popup toolbar --> On new region.
I just did a fresh install and the setting is sticking. Need to confirm on my portable version later tonight as I left my drive at home ...
thanks 1 user thanked ElSid for this useful post.
on 17/03/2017(UTC)
#74 Posted : 18 March 2017 04:21:52(UTC)
That is the problem!The movable tool bar is active only after doing all that.It used to pop up @ step #1.
Once you have entered the writer region you have minimal options:
click on a word to Ctrl+B, Ctrl+U [bold, underline].
For the tool bar: click right, click left on 'settings'.
The minimal and advanced options is very ergonomic [to me].
Offline ElSid
#75 Posted : 07 September 2017 16:53:55(UTC)
ElSid
United States
Davide,
Where do we download the dictionary packages?
As a request, is there a way to override the default SMath text with this plugin?
UPDATE: First post points to FF, APACHE or LibreOffice ... I am trying the LibreOffice version in English
Now, is there a way to spell check the whole document or is it region by region?
Edited by user 07 September 2017 17:09:58(UTC)  | Reason: Found download
#76 Posted : 07 September 2017 21:11:36(UTC)
UPDATE: First post points to FF, APACHE or LibreOffice ...I am trying the LibreOffice version in English
Yes, some links are in the documentation file Good
Nope, region-by-region, at least for now. I've plans for this.
Offline Raztua
#77 Posted : 10 November 2017 17:57:18(UTC)
Raztua
Rank: Member
France
Was thanked: 2 time(s) in 2 post(s)
First,
Thanks a lots for this amazing pluggin.
I have two little problems with the Pluggin.
First, when i hopen the *.sm file with notepad and save it, it can't open the file with Smath.
Secondly, if i set as default profile a paragraph with indentation, it creates an error for the copy paste.
It is not a big issue for me, but i just wanted to raise the problems.
Thanks again for your work.
#78 Posted : 10 November 2017 19:38:05(UTC)
Originally Posted by: Raztua Go to Quoted Post
First,
Thank you for reporting these issues Good
Can you attach a small example of file that you cannot save with notepad? It is enough to open and save it to trigger the issue or you have to edit it?
Offline Raztua
#79 Posted : 13 November 2017 14:34:40(UTC)
Raztua
Rank: Member
France
Hi david,
I have checked at work, the following thing:
Test 1 : I create an empty spread sheet, create writter region with no indentation, save the doc, create a new empty doc, and copy paste the:
Quote:
<writer lang="eng"><![CDATA[<span style="font-family: 'Arial'; font-size: 10pt; font-weight: normal; font-style: normal; color: Black; background-color: Transparent; text-align: left; line-height: 115%">
<div>Test</div></span>]]></writer>
It works
Test 2 : I create an empty spread sheet, create writter region with indentation, save the doc, create a new empty doc, and copy paste the
Quote:
<region id="0" left="9" top="90" width="109" height="30" color="#000000" bgColor="#ffffff">
<div style="margin-left: 36pt">Test</div></span>]]></writer>
</region>
It works
Test 3: I create an empty spread sheet, create writter region with indentation, set the setting as default style, Create a new region, save the doc, i cant open it again. The code of the second region is
Quote:
<region id="1" left="0" top="135" width="113" height="30" color="#000000" bgColor="#ffffff">
<writer lang="eng"><![CDATA[<span style="font-family: 'Arial'; font-size: 10pt; font-weight: normal; font-style: normal; color: Black; background-color: Transparent; text-align: left; margin-left: 36pt; line-height: 115%">
<div>test2</div></span>]]></writer>
</region>
If i delete this part of the file, i can't open the doc again, But if i delete the property ; margin-left: 36pt; it works.
TL;TR The difference is the following:
</region>
</region>
I hope it helps,
And sorry for my poor english
Edited by user 13 November 2017 15:37:52(UTC)  | Reason: Not specified
thanks 1 user thanked Raztua for this useful post.
on 14/11/2017(UTC)
Offline ola_nicolas
#80 Posted : 22 December 2017 18:58:25(UTC)
ola_nicolas
Romania
Greetings.
In MathCAD, it is possible to obtain symbols consisting of two (or more) words separated by the pause, as in the attached picture. The practical way I have identified for this purpose is to copy the two (or more) words from a text region and place them in the first empty field of equality of definition. My question is: Is there similar feature in SMath? If so, how to proceed?
All the best.
Guest (13)
7 Pages«<23456>»
