Offline Paulius
#1 Posted : 14 November 2017 18:39:44(UTC)
Paulius
Lithuania
Is possible to make calculation in table, like excel?
Offline Alex M.
#2 Posted : 14 November 2017 22:34:30(UTC)
Alex M.
Not that I am aware off, but you can "connect" to EXCEL if you have it on your windows machine:
https://en.smath.info/fo...n-and-export-to-PNG.aspx
#3 Posted : 15 November 2017 02:09:50(UTC)
Your question is too vague, a bit of work sheet would help.
In short: there is no known limit about what Smath can do
within a matrix [its own matrix] wrt the project you are Engineering.
Then, you may send to Excel via Alex plugin.
Alex, please correct me if wrong !
Cheers.
Offline Peter J Francis
#4 Posted : 15 November 2017 10:54:27(UTC)
Peter J Francis
Rank: Member
United Kingdom
Hi Paulius,
I had a similar problem.
I wanted to create a table of values for a project at work that could be easily read by non SMath people (i.e. I wanted a nice looking table but also array names with text to identify the value rather than numbers)
Some of the values were fixed (sizes , powers or text ) but I needed to perform calculations on some of the values and incorporate it in a table.
I came up with the following method using TableRegions , although it looks a little complicated it works great and generates a great looking table and I can use arrays with meaning full text identifiers.
The attached file is annotated so should be fairly self explainatory and there are some examples of how to use the values at the bottom.
If you have a problems with it let me know.
TableRegion example by PJF.sm (31kb) downloaded 151 time(s).
Peter
Peter J Francis
Twitter: @PeterJFrancis
Thermal Engineer , Maker , Pilot
Offline Paulius
#5 Posted : 15 November 2017 15:26:33(UTC)
Paulius
Lithuania
Tnank You Peter
#6 Posted : 15 November 2017 17:49:34(UTC)
Thanks Peter: gorgeous ! mm² ... mm[Alt+253]
Hi Paulis ... here is some bed time reading
Rotate Eol.sm (29kb) downloaded 29 time(s).
Utilities Matrix Truth Table.sm (60kb) downloaded 38 time(s).
0Anim Brownian.sm (10kb) downloaded 15 time(s).
2D Fill Stem.sm (13kb) downloaded 18 time(s).
0Anim Ellipse.sm (14kb) downloaded 17 time(s).
0Anim Analemma.sm (30kb) downloaded 13 time(s).
Inst_Colebrook Pipe Data.sm (61kb) downloaded 20 time(s).
2D Isometric Copy.sm (78kb) downloaded 17 time(s).
Utilities Matrix Treasury Copy.sm (356kb) downloaded 29 time(s).
Rotate Image RGB.sm (349kb) downloaded 15 time(s).
Rotate Breather [4 Orientations].sm (1,001kb) downloaded 16 time(s).
Image ZOOM Cosmos RGB.sm (1,839kb) downloaded 20 time(s).
thanks 2 users thanked Jean Giraud for this useful post.
on 15/11/2017(UTC),  on 15/11/2017(UTC)
Offline Alex M.
#7 Posted : 16 November 2017 08:06:31(UTC)
Alex M.
Cheers.
Agree with Jean - you can do all sorts of operations in SMath with matricies and then present them as a table region OR you could use excel to do an present all the table stuff for you.
Guest (2)
