3 Pages<123>
Offline omorr
#21 Posted : 11 November 2017 13:44:05(UTC)
omorr
Rank: Administration
Serbia
Bumped into the problem of ODE Solvers plugin and the recent build. Started the example for ODE solving from the Martins's Reference book. Tried to delete and reinstall ODE Solvers, example started once and but the problem persisted after the second run.
Offline Andrey Ivashov
#22 Posted : 11 November 2017 16:37:38(UTC)
Originally Posted by: PompelmoTell Go to Quoted Post
The reported problem persists (post #11), but it is specified that it is only for the >= and not for <=, > , <.
Hello.
Unfortunately I can't reproduce an issue with >=. Could you please doublecheck? Version is 0.98.6523.
boolean_check_1.sm (6kb) downloaded 43 time(s).
#23 Posted : 11 November 2017 17:13:24(UTC)
Same problem here (regardless of formatting scheme, the screenshot is old style)
How about indicating the formatting scheme (e.g. in the status line)?
Online PompelmoTell
#24 Posted : 11 November 2017 18:25:53(UTC)
PompelmoTell
Martin has already answered for me.
SMath Studio: SMath Studio Desktop 0.98.6523.24281, x64
OS: Microsoft Windows NT 6.1.7601 Service Pack 1 (Windows 7 Professional Service Pack 1, x64)
Screen: 1920x1080 px, 96x96 dpi, 96 GP.DPI, 1 GP.SRF
Localization: separator=<semicolon>; decimal symbol=<period>; system decimal symbol=<comma>; language=ITA
Frameworks: CLR 2.0.50727.8762
installed versions:
v2.0.50727 2.0.50727.5420 SP2
v3.0 3.0.30729.5420 SP2
v3.5 3.5.30729.5420 SP1
v4
Client 4.7.02053
Full 4.7.02053
v4.0
Client 4.0.0.0
#25 Posted : 11 November 2017 23:33:55(UTC)
Just say "Yes continue" and open the work sheet.
Done otherwise: double click on the file from it's location,
"Yes, continue" it should open the work sheet all functional.
ODE Predator Prey [rkfixed Cauchy].sm (8kb) downloaded 55 time(s).
#26 Posted : 12 November 2017 05:11:07(UTC)
Bolean should be specified completely. The example > ... < is trivial
If not specified completely, all sorts of error messages will be issued.
Mathcad was more tolerant, thus much less educative than Smath.
DeBoor argument v< ... is however completely specified wrt to its neighbour
if((el(u,μ)≤v)&(v<el(u,μ+1)),1,0)
Vector Maths.sm (1,089kb) downloaded 42 time(s).
Offline agualdron
#27 Posted : 12 November 2017 16:25:48(UTC)
agualdron
Colombia
I can't run the new beta Sad
Ubuntu 16.04 64bit
Mono JIT compiler version 4.2.1 (Debian 4.2.1.102+dfsg2-7ubuntu4)
This is what i get from the command line:
SMathStudioDesktop.0_98_6523.Mono$ mono SMathStudio_Desktop.exe
Could not set X locale modifiers
- [AppDir] Special Functions 1.11.6523.24283 (2 ms.)
- [UserDir] Development Tools 1.0.6498.3892 (1 ms.)
- [AppDir] HTML Export 1.13.6523.24283 (0 ms.)
- [AppDir] Export to image 1.9.6523.24284 (0 ms.)
- [AppDir] Picture Region 1.10.6523.24284 (0 ms.)
- [AppDir] Plot Region 1.9.6523.24284 (1 ms.)
- [AppDir] SMath Studio Files Plugin 1.9.6523.24284 (0 ms.)
- [AppDir] Standard Toolbox Buttons 1.0.6523.24285 (0 ms.)
- [AppDir] Text Region 1.10.6523.24284 (0 ms.)
- [AppDir] SMath Viewer Files Plugin 1.1.6523.24285 (0 ms.)
- [AppDir] XMCD Files Plugin 1.12.6523.24284 (0 ms.)
Unhandled Exception:
System.ArgumentException: The requested FontFamily could not be found [GDI+ status: FontFamilyNotFound]
at System.Drawing.GDIPlus.CheckStatus (Status status) <0x41a9a000 + 0x00753> in <filename unknown>:0
at System.Drawing.Font..ctor (System.Drawing.FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont) <0x41acfde0 + 0x000c3> in <filename unknown>:0
at System.Drawing.Font..ctor (System.Drawing.FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit) <0x41acfd40 + 0x0004b> in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Font:.ctor (System.Drawing.FontFamily,single,System.Drawing.FontStyle,System.Drawing.GraphicsUnit)
at SMath.Control.PaintContext.EquationsFont (Single fontSize) <0x41c05940 + 0x0007f> in <filename unknown>:0
at SMath.Control.PaintContext.set_NormalFont (System.Drawing.Font value) <0x41c04bc0 + 0x00a43> in <filename unknown>:0
at SMath.Control.MathRegion.GetPaintContext (Rectangle r, System.Drawing.Graphics g) <0x41c04740 + 0x000ff> in <filename unknown>:0
at SMath.Control.MathRegion.Prepare (System.Drawing.Graphics g, System.Windows.Forms.PaintEventArgs e) <0x41c042d0 + 0x00123> in <filename unknown>:0
at SMath.Control.MathRegion.PrePainter () <0x41c042a0 + 0x00013> in <filename unknown>:0
at SMath.Control.RegionBase.InitLayout () <0x41c03fd0 + 0x00279> in <filename unknown>:0
at SMath.Control.Worksheet.ElementCreater (SMath.Control.RegionBase region, Boolean makeCurrent, Boolean batchProcessing, Boolean invalidateRequired) <0x41c009e0 + 0x0021d> in <filename unknown>:0
at SMath.Control.Worksheet.CreateRegions (IEnumerable`1 newRegions, Boolean showProgress, LocationCorrectionMode locationCorrection) <0x41bff410 + 0x006af> in <filename unknown>:0
at (wrapper remoting-invoke-with-check) SMath.Control.Worksheet:CreateRegions (System.Collections.Generic.IEnumerable`1<SMath.Control.RegionBase>,bool,SMath.Control.LocationCorrectionMode)
at ...ctor (System.Collections.Generic.List`1 ) <0x41b4a000 + 0x01d13> in <filename unknown>:0
at (wrapper remoting-invoke-with-check) .:.ctor (System.Collections.Generic.List`1<string>Wink
at .. (System.String[] ) <0x41a5adc0 + 0x001cf> in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.ArgumentException: The requested FontFamily could not be found [GDI+ status: FontFamilyNotFound]
Hope this help...
Offline Alex M.
#28 Posted : 12 November 2017 17:32:37(UTC)
Alex M.
here you are :-)
Offline omorr
#29 Posted : 12 November 2017 22:03:33(UTC)
omorr
Serbia
Unfortunately, this will not work for me (Windows 10, 32bit)
Offline uni
#30 Posted : 14 November 2017 10:14:55(UTC)
uni
Edited by user 14 November 2017 10:17:37(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
Offline alyles
#31 Posted : 14 November 2017 16:01:27(UTC)
alyles
United States
I'm running Win7 64-Bit if it helps
#32 Posted : 14 November 2017 18:54:00(UTC)
Otherwise useful 6179
#33 Posted : 16 November 2017 00:02:43(UTC)
Thank you all for your comments!
Topic updated - new SMath Studio 0.98.6528 released.
New visualization approach improved again. The main change is that support of Linux restored and "more or equal" operator should be fixed now. Also, the following functions looks much better now: int(2), int(4), for(3), for(4), sum(1), sum(4), product(4), range(2), range(3). On Windows operators do not look blured anymore.
Formatting preset option will be removed from the next build ("Default" will be used as an only built-in one).
Please try and comment.
Best regards, Andrey Ivashov.
Edited by user 16 November 2017 00:30:04(UTC)  | Reason: Not specified
thanks 3 users thanked Andrey Ivashov for this useful post.
on 16/11/2017(UTC),  on 16/11/2017(UTC),  on 16/11/2017(UTC)
Offline alyles
#34 Posted : 16 November 2017 00:26:55(UTC)
alyles
United States
Can confirm fix for >= sign.
thanks 1 user thanked alyles for this useful post.
on 16/11/2017(UTC)
Offline alyles
#35 Posted : 16 November 2017 00:41:22(UTC)
alyles
United States
Tested the rest of functions you stated. They look pretty good scaling seems much better.
#36 Posted : 16 November 2017 02:17:57(UTC)
Better Good
A couple of issues I still found: horizontal alignment of factorial and vertical ellipsis
Broken right bracket of matrices changing font sizes (starting from 16pt):
EDIT linux still not working for me
Edited by user 16 November 2017 13:30:26(UTC)  | Reason: Not specified
on 16/11/2017(UTC)
Offline gabben
#37 Posted : 16 November 2017 13:59:47(UTC)
gabben
Sweden
Clap
I'm having some problems with the for(3) dots being out of place, using the latest build and default formatting.
Update:
Alright, so now Ive had several hard crashes when Smath is being used. Seems as if I loose the standard language / grid settings, and when I try to open settings I get this:
Edited by user 16 November 2017 15:56:18(UTC)  | Reason: Update with crashes
#38 Posted : 16 November 2017 20:26:49(UTC)
Should work for triple as well ?
#39 Posted : 17 November 2017 02:07:40(UTC)
Thank you very much for the reports!
My stupid error. Already fixed. Sorry.
#40 Posted : 17 November 2017 02:09:38(UTC)
Yes, it works:
3 Pages<123>
