Offline Nils
#1 Posted : 01 January 2018 21:40:40(UTC)
Nils
as you can see in the example below here is another problem with units in smath.
As a civil engineer I need to have pressure-values to be printed in [kN/m²] and smath
prints results of calculations in [J/m³] by default. When I try to change the unit manually, a redundant expression
in the form of [m³/m³] appears and cannot be deleted. Not only that this does not look nice - this
"new unit" cannot be combined with other values having been define in [kN/m²] by me.
I suspect that there is a logic behind this I don't understand. So please help me if you have a clue.
Thank you, Nils minimum example.sm (8kb) downloaded 19 time(s).
Offline overlord
#2 Posted : 01 January 2018 22:36:55(UTC)
Turkey
Was thanked: 509 time(s) in 339 post(s)
nothing is wrong with unit handling in this example except your misinterpretation.
my guess is you copy-paste the meter cube and meter square from somewhere else.
you should recheck how you handle with power for your formulas.
regards
minimum_1.sm (8kb) downloaded 29 time(s).
Offline Nils
#3 Posted : 02 January 2018 00:32:28(UTC)
Nils
Hello overlord,
you were totally right. I was handling the power wrong... just found out that I have to press the key twice to have it correctly.
Thank you for spending your precious evening time with helping a newbie out.
May the power be with you,
Nils
#4 Posted : 02 January 2018 02:31:40(UTC)
Offline FBRamires
#5 Posted : 26 January 2018 18:37:49(UTC)
FBRamires
Brazil
Dear,
in my file is experiencing a similar event, I would like, if possible, any tips on the error that I am commenting and a possible solution.
Thank you!
Error_unit.tif (94kb) downloaded 14 time(s).
regards
Offline alyles
#6 Posted : 26 January 2018 19:07:45(UTC)
alyles
United States
FBRamires,
You need to set your units in I.2 to (kPa)^2 and units of I.3 to (kPa)^3.
Edit: See this example
Edited by user 26 January 2018 19:13:59(UTC)  | Reason: Not specified
