2 users thanked Ber7 for this useful post.
on 29/12/2017(UTC), on 24/01/2018(UTC)
Tanks Ber7: saved in your named file.
Vibrations of a rectangular membrane Calculation formulas are taken from the book:S.Timoshenko, Vibration Problems In Engineering MemPl.sm (15kb) downloaded 129 time(s).Edited by user 19 April 2022 17:38:55(UTC)
3 users thanked Ber7 for this useful post.
on 06/01/2018(UTC), on 06/01/2018(UTC), on 24/01/2018(UTC)
on 20/01/2018(UTC), on 24/01/2018(UTC)
Deflection of simply supported equilateral triangular plate The plate rests on a frame in the form of an equilateral triangle. The triangular part of the plate is loaded uniformly distributed load. The equation of the surface of deflections of a triangular plate is taken from the book of S.P.Timoshenko.Timoshenko S.P., Woinowsky-Krieger S. Theory of plates and shells. New York, NY: McGraw-Hill; 1959. triangular plate.sm (13kb) downloaded 72 time(s).Edited by user 19 April 2022 18:12:24(UTC)
on 20/01/2018(UTC), on 20/01/2018(UTC), on 24/01/2018(UTC)
Thanks Ber7 for that one and the other one few days ago.
I tried to use the plugin Maxima PlateMaxima.sm (144kb) downloaded 84 time(s).Edited by user 19 April 2022 18:21:48(UTC)
on 24/01/2018(UTC), on 25/01/2018(UTC)
Originally Posted by: Ber7 I tried to use the plugin Maxima Thanks Ber7, I love those 3D, though it will never beat Mathcad 8... 11. On my own, I published several times more than the entire Mathcad Community. I don't miss them in Smath 6179, why ? purely useless for the Engineer. They are just for the Gallery [Tom G. would say Peanut Gallery]. We are just waiting for a stable Smath version delivered with Maxima plugin and more of the possible plugins. Scilab looks far superior to Maxima ?
Deflection of a Circular Plate.Plate contains rigid inclusion of radius b and loaded at the Center (Timoshenko,S.and Woinowsky-Krieger, S.,Theory of plates and shells, 1959) Inclusion.sm (33kb) downloaded 71 time(s).
1 user thanked Ber7 for this useful post.
Hello Beer7, is this vibration of a rectangular membrane equivalent to the deflection of a simply supported, uniformly loaded, rectangular plate? (leaving aside the physical parameters like plate thickness, Young's modulus etc.) I am only interested in the curvature on various locations on the surface, not in absolute values (max deflection can be calculated using simple civil engineering formulaes). Thanks, Laurent Originally Posted by: Ber7
Originally Posted by: Ber7 Vibrations of a circular membrane.The axis symmetric case Solutions are described with the help of Bessel functions . Thanks Ber7, works great. Beautiful work. mwbesselj(0,x) is ~ 4 times faster 15 decimals Hart JZERO 5852 is 23 decimals up to ± 8. Cheers ... Jean Bessel JY.sm (76kb) downloaded 53 time(s).
Originally Posted by: Jean Giraud Vibrations of a circular membrane.The axis symmetric case Solutions are described with the help of Bessel functions . What happened, your previous post is gone with the wind ??? Try this, so much faster ! Bessel mwbesselj Membrane Ber7 [20190126].sm (32kb) downloaded 75 time(s).
Thanks, works fine after doctoring CreateMesh.
