Hello
The problem is with SMath Studio Desktop 64, 0.98.6606
If there is a closed Area region on screen the small red cross is not moving if the arrow keys are used or if Enter is pressed. It actually moves, but it remains at the same place on the screen.
If the closed Area is not visible (eg. after scrolling down) there is no problem If the Area is open, there is no problem either
Regards, Istvan
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Confirmed. Applies to the classic view mode only. Edited by user 07 February 2018 14:59:31(UTC)
| Reason: FIXED |
Hi It seems something is still not perfect in 64bit, 0.99.6611 on Win10 Somehow the red cross is not updated if a closed area region is visible on the screen, if I scroll and it goes out from the screen, then everything is OK. In this file cursor keys.avi (1,768kb) downloaded 23 time(s). I try to move the cross with the cursor keys, first with the closed area visible, second when it is not. Something very similar happens when Enter is pressed
Hello.
Please check if you can reproduce this with latest SMath Studio 6619.
Hello
Thanks, it is definitely fixed in 6622
Regards, Istvan
