5 Pages<12345>
#41 Posted : 11 November 2017 03:21:13(UTC)
Originally Posted by: alyles Go to Quoted Post
I get an issue trying to install Zedgraph plugin with most recent beta. Not sure if it worked in previous versions.
Few days ago, ZedGraph was reported not working.
Today, I downloaded "Filter response" that has the lo-log ZedGraph.
It couldn't find it in version 6179, said yes to "continue",
here is the log-log plot working in 6179. I checked the "Insert"
menu ... now it is in the "Insert" menu.
It might install itself for you like it did for me ... try .
Offline uni
#42 Posted : 11 November 2017 08:29:20(UTC)
uni
I get an issue trying to install Zedgraph plugin with most recent beta. Not sure if it worked in previous verions.
Anyways it throws an exception. I attached the text.
I'm running SMath 0.98.6522
You need administrator rights to run. The location of the extensions folder is strange ('C:\Program Files (x86)\SMath Studio\extensions\' ). Usually it is located in a %user%\AppData folder. Maybe you need to completely uninstall the program and reinstall it without administrator rights.
Russia ☭ forever
Viacheslav N. Mezentsev
on 13/11/2017(UTC)
#43 Posted : 11 November 2017 11:45:43(UTC)
This might happen if a portable distribution has been stored under 'C:\Program Files (x86)\SMath Studio' or an ordinary installer version has been made portable (by placing a file portable.version in the install dir).
on 13/11/2017(UTC)
Offline alyles
#44 Posted : 13 November 2017 16:15:53(UTC)
alyles
United States
thanks. Re-ran SMath with Admin rights and it seemed to clear up. I did have portable distribution in there at some point
Offline krissn
#45 Posted : 06 February 2018 14:13:18(UTC)
krissn
Rank: Member
United Kingdom
Inserting zedgraph cause:
Unhandled exception has occured...
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.FileNotFoundException: Could not find file 'ZedGraphRegion.resources'.
at System.Reflection.RuntimeAssembly.InternalGetSatelliteAssembly(String name, CultureInfo culture, Version version, Boolean throwOnFileNotFound, StackCrawlMark& stackMark)
at System.Resources.ManifestBasedResourceGroveler.GetSatelliteAssembly(CultureInfo lookForCulture, StackCrawlMark& stackMark)
at System.Resources.ManifestBasedResourceGroveler.GrovelForResourceSet(CultureInfo culture, Dictionary`2 localResourceSets, Boolean tryParents, Boolean createIfNotExists, StackCrawlMark& stackMark)
at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo requestedCulture, Boolean createIfNotExists, Boolean tryParents, StackCrawlMark& stackMark)
at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents)
at System.Resources.ResourceManager.GetString(String name, CultureInfo culture)
at ZedGraphPlugin.ZedGraphControl..ctor(SessionProfile sessionProfile)
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark)
at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Activator.CreateInstance(Type type, Object[] args)
at SMath.Control.RegionHolder`1..ctor(SessionProfile sessionProfile)
at ZedGraphPlugin.ZedGraph..ctor(SessionProfile sessionProfile)
at ZedGraphPlugin.PluginRegion.InsertZedGraphRegionHolder(MenuButtonArgs args)
at ..(Object , RegionBase , MenuButton )
at ...(Object , EventArgs )
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.2633.0 built by: NET471REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
SMathStudio_Desktop
Assembly Version: 0.98.6606.22071
Win32 Version: 1.1.28.0
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMathStudio_Desktop.exe
SMath.Manager
Assembly Version: 0.98.6606.22069
Win32 Version: 0.98.6606.22069
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Manager.DLL
Win32 Version: 4.7.2556.0 built by: NET471REL1
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
Win32 Version: 4.7.2612.0 built by: NET471REL1LAST_B
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
SMath.Controls
Assembly Version: 0.98.6606.22070
Win32 Version: 0.98.6606.22070
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Controls.DLL
SMath.Math.Symbolic
Assembly Version: 1.32.6606.22070
Win32 Version: 1.32.6606.22070
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Math.Symbolic.DLL
SMath.Math.Numeric
Assembly Version: 1.65.6606.22070
Win32 Version: 1.65.6606.22070
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.Math.Numeric.DLL
SpecialFunctions
Assembly Version: 1.11.6606.22071
Win32 Version: 1.11.6606.22071
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SpecialFunctions.dll
CustomFunctions
Assembly Version: 1.1.6522.6678
Win32 Version: 1.1.6522.6678
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/18dadffd-79a3-4cf9-aee1-d66deb0ea720/1.1.6522.6678/CustomFunctions.dll
CustomGlyphs
Assembly Version: 1.1.6353.24538
Win32 Version: 1.1.6353.24538
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/24c691c1-37f2-49e3-9a84-ccb77304d14a/1.1.6353.24538/CustomGlyphs.dll
ElectricalEngineeringLibrary
Assembly Version: 0.2.6353.24636
Win32 Version: 0.2.6353.24636
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/3fd1f9ba-53ee-4665-966b-bd2805a84485/0.2.6353.24636/ElectricalEngineeringLibrary.dll
MaximaPlugin
Assembly Version: 1.98.6519.13993
Win32 Version: 1.98.6519.13993
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.6519.13993/MaximaPlugin.dll
SharpVectors.Rendering.Gdi
Assembly Version: 0.3.1.1595
Win32 Version: 0.3.1.1595
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.6519.13993/SharpVectors.Rendering.Gdi.DLL
SharpVectors.Core
Assembly Version: 0.3.1.1588
Win32 Version: 0.3.1.1588
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.6519.13993/SharpVectors.Core.DLL
SharpVectors.Model
Assembly Version: 0.3.1.1592
Win32 Version: 0.3.1.1592
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.6519.13993/SharpVectors.Model.DLL
SharpVectors.Css
Assembly Version: 0.3.1.1590
Win32 Version: 0.3.1.1590
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.6519.13993/SharpVectors.Css.DLL
SharpVectors.Dom
Assembly Version: 0.3.1.1589
Win32 Version: 0.3.1.1589
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/44011c1e-5d0d-4533-8e68-e32b5badce41/1.98.6519.13993/SharpVectors.Dom.DLL
HyperlinkRegion
Assembly Version: 1.0.6362.5973
Win32 Version: 1.0.6362.5973
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/4938d1a8-ad11-4de8-afbf-d76d069cfbf8/1.0.6362.5973/HyperlinkRegion.dll
TableRegion
Assembly Version: 0.2.6610.42543
Win32 Version: 0.2.6610.42543
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/51fec712-ec75-4551-a13e-478d375ae8d6/0.2.6610.42543/TableRegion.dll
DataExchange
Assembly Version: 1.1.6499.5086
Win32 Version: 1.1.6499.5086
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/5dce7298-9e5f-4120-9a2e-49b16daa02a3/1.1.6499.5086/DataExchange.dll
PdfFileType
Assembly Version: 1.0.6353.25356
Win32 Version: 1.0.6353.25356
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.6353.25356/PdfFileType.dll
PdfSharp
Assembly Version: 1.32.2608.0
Win32 Version: 1.32.2608.0
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/ac3d62dc-d93d-4c91-88e2-06a01fd2b5cc/1.0.6353.25356/PdfSharp.DLL
PictureRegion
Assembly Version: 1.10.6606.22071
Win32 Version: 1.10.6606.22071
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PictureRegion.dll
ZedGraphRegion
Assembly Version: 0.1.6520.39127
Win32 Version: 0.1.6520.39127
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/b0e7602f-c9d4-4e6c-b6f1-087e4c6e8915/0.1.6520.39127/ZedGraphRegion.dll
System.Design
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
DevelopmentTools
Assembly Version: 1.0.6498.3892
Win32 Version: 1.0.6498.3892
CodeBase: file:///C:/Users/kszmurlo/AppData/Roaming/SMath/extensions/plugins/f406188b-ff0e-4b02-8b05-8d6fda91e357/1.0.6498.3892/DevelopmentTools.dll
System.Management
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
HTMLFileType
Assembly Version: 1.13.6606.22071
Win32 Version: 1.13.6606.22071
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/HTMLFileType.dll
ImageFileType
Assembly Version: 1.9.6606.22072
Win32 Version: 1.9.6606.22072
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ImageFileType.dll
PlotRegion
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/PlotRegion.dll
SMathFileType
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/SMathFileType.dll
StandardToolboxButtons
Assembly Version: 1.0.6606.22072
Win32 Version: 1.0.6606.22072
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/StandardToolboxButtons.dll
SMath.UI
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/SMath.UI.DLL
TextRegion
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/TextRegion.dll
ViewerFileType
Assembly Version: 1.1.6606.22072
Win32 Version: 1.1.6606.22072
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/ViewerFileType.dll
XMCDFileType
Assembly Version: 1.12.6606.22072
Win32 Version: 1.12.6606.22072
CodeBase: file:///C:/Program%20Files%20(x86)/SMath%20Studio/plugins/XMCDFileType.dll
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Offline Andrey Ivashov
#46 Posted : 06 February 2018 21:55:13(UTC)
Rank: Administration
ZedGraph Region must be fixed:
I've realized it is because of SMath Studio uses .Net 4.0 when available on the machine. For some reason .Net 4.0 trying to search for .resources file, which does not exist in the plug-in at all.
It is easy to fix this by removing resources files from the plug-in project (so, the text entries will be hardcoded), but I do not think it is a best choice.
See also: https://social.msdn.micr...ourcesdll?forum=netfxbcl
Edited by user 06 February 2018 22:26:33(UTC)  | Reason: Not specified
on 18/02/2018(UTC)
#47 Posted : 06 February 2018 22:44:39(UTC)
Ok, the following line fixed issue:
Quote:
Resources.Culture = CultureInfo.InvariantCulture;
New version of the plug-in released and available via Extensions Manager. Please update it to use with latest SMath Studio builds.
on 07/02/2018(UTC),  on 07/02/2018(UTC)
Offline krissn
#48 Posted : 18 February 2018 01:56:42(UTC)
krissn
Rank: Member
United Kingdom
Thanks that works now!
Offline uni
#49 Posted : 23 June 2018 04:09:12(UTC)
uni
Updated, refactored.
zedgraph1.pdf (28kb) downloaded 109 time(s).
Russia ☭ forever
on 23/06/2018(UTC)
Offline uni
#50 Posted : 26 June 2018 12:29:31(UTC)
uni
Updated. The file size reduced (points removed).
ZedGraph Examples.sm (174kb) downloaded 148 time(s).
ZedGraph Examples.pdf (106kb) downloaded 177 time(s).
Edited by user 26 June 2018 12:32:32(UTC)  | Reason: Not specified
Russia ☭ forever
on 26/06/2018(UTC),  on 26/06/2018(UTC),  on 27/06/2018(UTC)
Offline uni
#51 Posted : 05 July 2018 22:17:16(UTC)
uni
Updated. Fixed bug when zooming.
Russia ☭ forever
Offline joaobr
#52 Posted : 19 April 2020 18:56:18(UTC)
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
Hi!
The configurations of my ZedGraph region is not maintained when using the Viewer (free version).
Is there some specific configuration I should check?
Offline uni
#53 Posted : 19 April 2020 19:08:56(UTC)
uni
Can you specify what exactly do you mean? The formatting dialog appears when you double-click on the chart.
Russia ☭ forever
Offline joaobr
#54 Posted : 19 April 2020 19:42:22(UTC)
joaobr
Brazil
I didn't know that. But is there a way to freeze the configurations set in the .sm when creatng the .exe?
I don't want users to mind about it.
Offline uni
#55 Posted : 20 April 2020 07:08:24(UTC)
uni
This is bug. I'll try to find out what is the problem.
Russia ☭ forever
Offline joaobr
#56 Posted : 20 April 2020 14:35:00(UTC)
joaobr
Brazil
Thanks!
Offline Andreas Hildebrandt
#57 Posted : 21 April 2020 21:17:27(UTC)
Andreas Hildebrandt
Hello, I have a question regarding ZedGraph.
I want to set the axis range (xmax and ymax) from the calculation sheet.
If I use the XY-Plot this is possible using the setprop() function or
by setting the value of the variable "XYPlot.XLimMax" to the desired value.
How can this be done using ZedGraph? I assume that it is although possible with
the setprop() function but I don't know the name and the syntax of the
corresponding variable. Can anyone give me a hint?
Thanks in advance
Andreas Hildebrandt
Offline uni
#58 Posted : 22 April 2020 09:19:59(UTC)
uni
Theoretically, this is possible, but now there is one small problem that I have not yet solved. The problem is setting indexed properties. For the same reason, the properties of curves for X-Y Plot are not yet available for changing. I will let you know when this can be done.
Russia ☭ forever
on 22/04/2020(UTC)
#59 Posted : 22 April 2020 09:42:52(UTC)
Andreas Hildebrandt
Thank you very much for your quick reply. At the moment it seems to me that I don't need access to an indexed property.
For XY-Plot
setprop("Test_Plot.XAxis.Max",<value> )=
works perfect. To identify the plot there is a property "NAME".
(In the example above the name is "Test_Plot" ).
Now I tried to do the same for ZedGraph.
setprop("myPane.XAxis.Scale.Max",<value> )=
But ZedGraph has no property called "NAME".
Now the question: Is there any string
for "myPane" to identify the ZedGraph-Plot
to set the value of XAxis.Scale.Max?
Thanks in advance for your help!
Andreas Hildebrandt
Edited by moderator 22 April 2020 10:05:11(UTC)  | Reason: Not specified
Offline uni
#60 Posted : 22 April 2020 12:32:16(UTC)
uni
Updated. Experimental build. Be careful with this. You need to update X-Y Plot first.
P.S. "Name" property is not saved. This will be more difficult to fix, as component uses a binary format for storing settings.
Edited by user 22 April 2020 13:20:45(UTC)  | Reason: Not specified
Russia ☭ forever
on 22/04/2020(UTC),  on 22/04/2020(UTC),  on 11/10/2023(UTC)
Guest (2)
5 Pages<12345>
