Offline Razonar
#1 Posted : 19 February 2018 06:34:45(UTC)
Razonar
Uruguay
Hi. I'm trying to implement this implicit plot. But can't "cut" the lines in the xy plot. Also, any help about speeding the function is welcome.
iplotq.sm (41kb) downloaded 62 time(s).
Offline Ber7
#2 Posted : 19 February 2018 10:35:55(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Try the method of Draghilev
DragilevMet.sm (25kb) downloaded 41 time(s).
Edited by user 21 October 2018 20:28:06(UTC)  | Reason: Not specified
Offline Razonar
#3 Posted : 19 February 2018 12:07:23(UTC)
Razonar
Uruguay
Hi Ber. Thanks for the implementation. But it use maple and is semisymbolic, I want just some that can works in the cloud, like: https://en.smath.info/cloud/sheet/s23Pa6bZUn
Offline Ber7
#4 Posted : 19 February 2018 12:38:09(UTC)
Ber7
Israel
Option without Maple
DragilevMet1.sm (22kb) downloaded 39 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 19/02/2018(UTC)
Offline Razonar
#5 Posted : 19 February 2018 13:13:37(UTC)
Razonar
Uruguay
Perfect! Thanks.
Offline CBG
#6 Posted : 20 February 2018 01:22:41(UTC)
CBG
Not graphic
It does not show any error
Offline Razonar
#7 Posted : 20 February 2018 03:28:12(UTC)
Razonar
Uruguay
Hi Carlos
For see the error message type B1=
Offline CBG
#8 Posted : 20 February 2018 05:44:57(UTC)
CBG
Hello Alvaro:
Thank you very much.
The error in the graph is that x is not defined.
What causes this error?
In the graphs published by you it is seen that graphs correctly.
Offline Razonar
#9 Posted : 22 February 2018 09:11:16(UTC)
Razonar
Uruguay
Hola Carlos. Try the following, a short version, just for n=2.
DragilevMet2.sm (13kb) downloaded 34 time(s).
on 22/02/2018(UTC)
Offline Ber7
#10 Posted : 22 February 2018 10:21:24(UTC)
Ber7
Israel
Try also the old version of the Draghilev method
DragilevMet3.sm (24kb) downloaded 27 time(s).
Razonar,thanks for the short code for n = 2
Edited by user 21 October 2018 20:29:28(UTC)  | Reason: Not specified
#11 Posted : 22 February 2018 20:45:42(UTC)
Carlos, Alvaro,
From previous use of Dragilev method, I observed great difficulties
to appropriately start/stop rkfixed. Your example above works fine as is.
For more points with less tentatives in specific cases, the easiest way
is to pass it to the closed shape Hermite suite.
I should revisit some of those examples.
The Esplina AI2000 interpolates as well for closed shapes.
Spline Esplina [AI2000].sm (22kb) downloaded 21 time(s).
Spline Esplina [Hermite].sm (36kb) downloaded 23 time(s).
on 22/02/2018(UTC)
Offline CBG
#12 Posted : 22 February 2018 21:55:44(UTC)
CBG
By--> Razonar
By--> Ber7
Quote:
Try also the old version of the Dragilev method
DragilevMet3.sm (24kCool downloaded 10 time(s)
Hola Alvaro, Hello Ber7,
Thanks for your reply, but the DragilevMet2 and 3 files do not work.
The file of Ber 7 does not show any error, but by requiring the value
of B1 and B2, it says that "x" is not defined.
Attached drawing of the errors.
Hello Jean, your files worked perfectly.
Offline Razonar
#13 Posted : 23 February 2018 09:19:44(UTC)
Razonar
Uruguay
Hola Carlos.
It's because a problem with rkfixed routine in your environment. Try to download this, or use it in the cloud: DM_RK
Edited by user 25 February 2018 00:49:18(UTC)  | Reason: Not specified
Offline CBG
#14 Posted : 23 February 2018 21:56:57(UTC)
CBG
Hola Alvaro:
Gracias por tu respuesta.
Thanks for your answer, but I found the fault.
The interference is caused by the Maxima Plugin,
by disabling it, the file works correctly.
Offline CBG
#15 Posted : 24 February 2018 05:30:39(UTC)
CBG
Hola Alvaro
Here too, the problem is caused by the decimal separator "Point",
Changing in options, the decimal separator from "Point" to "Comma", (from "." To ","Wink
resolves the problem of graphing
thanks 1 user thanked CBG for this useful post.
on 25/02/2018(UTC)
Guest (2)
Similar Topics
2d Implicit Plot (Samples)
by Jean Giraud 19/05/2016 04:24:59(UTC)
