Was thanked: 3 time(s) in 1 post(s)
Hello friends. Is there a search/replace function in sMath Studio? Sometimes you decide to change a variable name from x to x1, for example. If there is a “search, replace all”, then you don’t have to do it one by one and it will save a lot of time.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
In a region, you can use the F8 key an you'll be able to rename all local variables/functions at once. Globally, you can do it with the Text Region Utilities plugin. |
Hello Davide, Thank you very much for your help. I downloaded 2 files: TextRegionUtilities.csproj and TextRegionUtilities.sln. How do I install them in sMath? And how do I use them to “replace all”? Thank you again friend.
In your Smath Studio, go to: Tools > Plugins... > [switch the top-right button: Local Storage > Online Gallery] and search the plugin, then double click it or click on the install button, that's all Edited by user 25 January 2018 13:55:12(UTC)
| Reason: typo |
Quote: In your Smath Studio, go to: Tools > Plugins... > [switch the top-right button: Local Storage > Online Gallery] and search the plugin, then double click it or click on the install button, that's all Good
Dear mr. Carpi When I have reached the Online Gallery according your instructions the notebook freezes completely. Only the cursor can be moved. A lot of windows can be opened but nothing can be executed. The notebook can only be switched off by swithing off the power. (Pushing the on/off switch during 5 seconds.) SMathStudiodesktop.099.6622 Lenovo Ideapad 500 Linux Mint 18 Cinnamon Best regards, oftheair
The F8 method works top/bottom within program, but fails partially in many more instances, just follow/watch what has been changed/replaced ... as you may have to do individually.
