Offline moaojanuel
#1 Posted : 27 February 2018 13:10:25(UTC)
moaojanuel
Portugal
Howdy,
I am relatively new to SMath (have used Mathcad in the past). I am trying to use SMath to run some engineering calculations. Particularly, I am interested in solving equations - I have used 'solve' function, but always get a "no real roots" message (see file attached).
Can someone help out?
Many thanks in advance!
J
#2 Posted : 27 February 2018 16:44:46(UTC)
Solving means a lot in Engineering works.
No real roots, indicates the solver is ill posed [generally]
Please, don't hesitate to post your problem, there is great expertise in Smath Community.
Maths bitcoin.sm (37kb) downloaded 76 time(s).
Solve General.sm (139kb) downloaded 116 time(s).
Solve TREASURY_0 [General].sm (120kb) downloaded 63 time(s).
#3 Posted : 27 February 2018 19:47:20(UTC)
Probably are you using the solve(2) function instead of the the solve(4) one (4 arguments, last 2 are the limits of the range where to search the roots)
Offline moaojanuel
#4 Posted : 27 February 2018 20:03:47(UTC)
moaojanuel
Portugal
Many thanks ALL for your valuable responses. While I understand what you are saying/showing on your templates, I still haven't managed to figure out what is wrong with the way the solve function is being employed. I have changed the roots range (-100, +100), tried the solve with 4arguments, and still nothing. Is there any chance someone could have a look at the file I have attached originally?
Many thanks,
J
#5 Posted : 27 February 2018 20:40:57(UTC)
There aren't attachments in your posts Good
Quote:
Edited by user 27 February 2018 20:44:43(UTC)  | Reason: Not specified
#6 Posted : 27 February 2018 21:37:49(UTC)
There is no *.sm document attached !
#7 Posted : 27 February 2018 23:10:19(UTC)
Offline moaojanuel
#8 Posted : 02 March 2018 15:46:16(UTC)
moaojanuel
Portugal
(Please ignore my post below - I can see the files have been uploaded after all Cool
Iff someone could have a look at the .sm file I have attached, I would be very grateful.
Many thanks,
Joao
SMath_equation solver test.zip (2kb) downloaded 46 time(s).
SMath_equation solver test.sm (9kb) downloaded 58 time(s).
SMath_equation solver test.sm (9kb) downloaded 60 time(s).
Hi ALL,
Many thanks for you interest and responses. Apologies for not having responded but I have been away from the office. I am trying to attach an .sm file, but for some reason this is not working... Any thoughts?
Thanks,
Joao
Edited by user 02 March 2018 15:48:49(UTC)  | Reason: attachment was uploaded after all
#9 Posted : 02 March 2018 16:31:55(UTC)
Will be back later during the day
#10 Posted : 02 March 2018 20:16:58(UTC)
solvers.sm (18kb) downloaded 64 time(s).
thanks 6 users thanked mkraska for this useful post.
on 02/03/2018(UTC),  on 02/03/2018(UTC),  on 02/03/2018(UTC),  on 03/03/2018(UTC),  on 03/03/2018(UTC),  on 03/03/2018(UTC)
#11 Posted : 03 March 2018 16:59:27(UTC)
"NO real roots" from the solve bloc is an absolute pest [not to say stupid].
SMath_equation solver test (1).sm (12kb) downloaded 82 time(s).
Offline moaojanuel
#12 Posted : 07 March 2018 13:18:35(UTC)
moaojanuel
Portugal
Dear ALL,
Many thanks for your incredible support! I am in awe for the depth of knowledge herein displayed.
With regards to your responses, I appreciate the need to make an appropriate substitution to overcome the fact that solve can't handle units in the variable; However, I can´t seem to assign the unit to the variable, within the equation (apologies for being thick). I've tried typing x'm, tried using ctrl+w to assign meters unit to x, but still haven't managed to make it work. A bit frustrating... If anyone could be so kind to shed some light here, that would be greatly appreciated.
Many thanks,
J
Edited by moderator 29 March 2018 12:49:15(UTC)  | Reason: marked as SOLVED
#13 Posted : 07 March 2018 19:08:03(UTC)
Dear ALL,
Many thanks,
J
Type x*'m or x* and then insert the unit from the dialog into the empty placeholder in the right of the multiplication dot.
Multiplication operators in front of units aren't shown.
#14 Posted : 08 March 2018 07:50:22(UTC)
With regards to your responses, I appreciate the need to make an appropriate substitution to overcome the fact that solve can't handle units in the variable; However, I can´t seem to assign the unit to the variable, within the equation (apologies for being thick). I've tried typing x'm, tried using ctrl w to assign meters unit to x, but still haven't managed to make it work. A bit frustrating... If anyone could be so kind to shed some light here, that would be greatly appreciated.
You are debating with the Unit SI as implemented in Smath [Mathcad ...]
You may pacify your soul on several counts:
1. maths are unit less
2. ISO standards have their own units [most generally from SI derived units].
... therefore converting automatically bar in Pa ... etc.
3. Engineering formulas are constructed around the appropriate Units
... therefore no need to freak them more.
4. Consider this example: you have a formula, from which you can directly/indirectly
compute the arc length ... in what SI units Watson ???
... simple Sherlook ... in "UnitGraphic" that you can meter in year-light/micrometer ...
5. How did we do in the age of the slide rule, in the age of paper/pencil/log tables ?
6. Was Sputnik launched from SI unit software ?
Offline jdoe1
#15 Posted : 29 December 2019 04:19:53(UTC)
jdoe1
I'm having a similar problem, it works on wolfram and symbolab, but not in Smath.
#16 Posted : 29 December 2019 05:32:16(UTC)
Always plot first ...
Offline jdoe1
#17 Posted : 30 December 2019 03:09:09(UTC)
jdoe1
I somehow missed the option to use the 2nd solve function with root limit, but I didn't need a plot for this, so I used it in one line and everything worked out fine.
I can't click the thank button, so thanks.
#18 Posted : 30 December 2019 05:01:26(UTC)
If you don't plot, you will soon hit the wall.
That will help set the limits.
When applicable, "implicit roots" is often + accurate.
