This is an amazing mathematical tool which is at the same level as some of the most sophisticated and expensive math software. I use it in all my classes and promote its use with all my engineering students.
more...
by Antonio Medrano
Found out that this software is as powerful as commercial softwares. Many thanks Andrey.
more...
by Harold Lopez
Smath is easy to use tool and its is freeware.I used for engineering calculations instead of easing excel. Its a time saver.
more...
by Naresh varikuntla
Edited by user 05 March 2018 21:06:14(UTC)
on 05/03/2018(UTC), on 05/03/2018(UTC), on 05/03/2018(UTC), on 05/03/2018(UTC), on 05/03/2018(UTC), on 06/03/2018(UTC), on 06/03/2018(UTC), on 06/03/2018(UTC), on 06/03/2018(UTC)
Originally Posted by: Jean Giraud For those interested to test useful functionalities 6638 Observe ... Q(i,j) is already code "trace"
Every time Smath Studio is updated, something goes wrong. Again failed to start the plugin Table Region, Smath Studio does not recognize it. Best Regards Carlos
Carlos, Originally Posted by: CBG Every time Smath Studio is updated, something goes wrong. Yeah, its a life... Fixed (please update a plug-in). Thank you!
It already works!
Thank you very much.
Originally Posted by: CBG Every time Smath Studio is updated, something goes wrong. That's why I'm 6179 for productive projects.
Originally Posted by: Jean Giraud Originally Posted by: CBG Every time Smath Studio is updated, something goes wrong. That's why I'm 6179 for productive projects. In this case you have to live with slow performance, tens of critical known (and already fixed) bugs. You can't use new features and make your future switch to newer version harder. There is no even any guarantee that your worksheets can be supported by latest SMath Studio versions (yeah, in SMath history we had couple of such situations when a part of calculation can not be handled anymore, unfortunately). So, I can't say that it is good approach.
Originally Posted by: Jean Giraud Are you kidding? And what about 2.35, -9.465 and etc?
A bug in functionality of vectorize() was introduced between 0.99.6617 and 0.99.6638. Will this be addressed? VectorizeBug.sm (7kb) downloaded 32 time(s).
Originally Posted by: Alex M. A bug in functionality of vectorize() was introduced between 0.99.6617 and 0.99.6638 That it was introduced between 6617 & 6638, that is surprising ? Even if it did work, to me, it is not correct because it will cause something wrong sooner or later, because to reflexive in the calculation kernel ... Murphy's law. I have experimented disastrous situations [crash ... push the button to stop]. Occasionally, to isolate, you have to spool to file. Cheers Alex ... Jean
Originally Posted by: Alex M. A bug in functionality of vectorize() was introduced between 0.99.6617 and 0.99.6638. Will this be addressed? Jean are right, this didn't work initially, but started working at some point because of another bug Yes, I'm not kidding. I've investigated this example and was able to make it work together with all other examples I have about vectorize(..) function. All tests executed OK. So, I decided to include this improvement into new release: https://en.smath.info/fo...6648--15-March-2018.aspxPlease test examples you have with vectorize(..) function. Best regards.
