your file says Code:
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<?application progid="SMath Studio Desktop" version="0.98.6179.21440"?>
This means you are complaining about an outdated version, which is just noise but no signal in the forum. Sort of discouraging spending time on such requests/reports. If you can't stop doing so, please at least mark clearly that you refer to an old version. |
The 1 in results with units was suppressed in SMath Studio 0.98.5935 (there is even a comment by Mike in that thread about this behavior) and doesn't apply anymore at least since the version 0.98.6606 (talking just about stable versions) right now I cannot find if this was fixed intentionally or not, however it seems is no more an issue currently Edited by user 06 March 2018 19:56:24(UTC)
Hello Jean The version "0.99.6638.17192" of Smath Studio does it correctly. I also propose a small change in the variable "Search" Best regards Carlos
Thanks Crlos,
Your'e right: just search for what is demanded.
Originally Posted by: Davide Carpi The 1 in results with units was suppressed in SMath Studio 0.98.5935 (there is even a comment by Mike in that thread about this behavior) and doesn't apply anymore at least since the version 0.98.6606 (talking just about stable versions) There is still a choice: |
