SMath Studio Forum
Questions
Show the Orignal Units in Table Region
Will it be possible? Units_Table.sm (8kb) downloaded 39 time(s).Best Regards Carlos
sets the header and units matrices sergio
1 user thanked PompelmoTell for this useful post.
Thanks Sergio: You made me remember the solution that Martin Kraska gave me, but I can not put a header on it. Do you have any suggestion? Units_Table_r2.sm (16kb) downloaded 53 time(s).Best Regards Carlos
I thought about this (string manipulation) but num2strtransforms into fractions sergio Edited by user 22 March 2018 20:45:08(UTC)
| Reason: conversion error between K and °C
Originally Posted by: CBG Will it be possible? I prefer the way we did in 1987, collecting piles of fluids information. Units_Table Preference.sm (13kb) downloaded 58 time(s).
Originally Posted by: PompelmoTell I thought about this (string manipulation) but num2strtransforms into fractions
sergio Use var2str() from CustomFunctions instead |
on 22/03/2018(UTC), on 22/03/2018(UTC)
Thank you very much to everyone for your help, I already managed to make the table as I required it. Units_Table_r3.sm (10kb) downloaded 57 time(s).Best Regards Carlos
2 users thanked CBG for this useful post.
on 23/03/2018(UTC), on 23/03/2018(UTC)
Joined: 02/04/2018(UTC) Posts: 135 Was thanked: 22 time(s) in 19 post(s)
CBG,
Using the unit summary to convert units back to original units doesn't work for temperature conversions. What you are doing with the units summary assumes the conversion is a factored multiplier. It works great for everything except temperature (or any other unit doesn't scale by a factored multiplier).
Originally Posted by: wb.c Using the unit summary to convert units back to original units doesn't work for temperature conversions. Just define those units.
Jean Giraud, Maybe try something other than 20 deg?... Version: 0.99(build: 6671)
Originally Posted by: wb.c Maybe try something other than 20 deg?...
You are quite right and there are two things here 1. As it looks, the °C can't be made user. The unit system is grounded on 'K', bloody pest to me. 2. The other thing is the Shadow in context, a real bug. It worked fine from Carlos original [by what coincidence ?] Not changing the context, context reproduces. Changing context and the all thing °C gets freaked. I observed that many times in Smath. In fact, very problematic. Thanks for this wise observation. Table Region Carlos.sm (11kb) downloaded 36 time(s).
SMath Studio Forum
Questions
