Simple and Elegant
more...
by Egbert Sales
May God reward the developers, for filling the vacuum left after MathCad. Thank you very very much.
more...
by Zsolt Roman
Excellent alternative to MathCad and it's free!
more...
by Marco Finlay
on 22/03/2018(UTC), on 22/03/2018(UTC), on 22/03/2018(UTC), on 22/03/2018(UTC), on 22/03/2018(UTC), on 23/03/2018(UTC)
The behaviour of loops with second value seems to have improved. Is this generally fixed or just by chance? |
Was thanked: 21 time(s) in 17 post(s)
Discovered following behaviour concerning pagebrakes with very long blocks: (scroll to right if necessary) The red marked block is so long, that it reaches the top of following page. As you can see in the preview window, the sheet content is not printed. Page 2 starts after the page brake with "Biegedrillknicken" when "Printing Bounds" is used. While using "Pages view", the first printed page looks the same (mostly white) but the second page starts with the skipped content "System l=5,00m..." Setting the font size only of the large block to something smaller so the bottom of it doesn't reach the page brake solves this issue.
Found another issue, while editing the description of a 2D plot: When you put the cursor in the description and edit the text, a matching variable in the input data is edited simultaneously. Screenshot: description is edited -> a second cursor appears in input data
Originally Posted by: MarB Found another issue, while editing the description of a 2D plot: Not clear w/o the document.
Originally Posted by: MarB Discovered following behaviour concerning page brakes with very long blocks: Maybe the problem is the construction ? Document would surely help volunteers.
Originally Posted by: Jean Giraud Originally Posted by: MarB Found another issue, while editing the description of a 2D plot: Not clear w/o the document. Originally Posted by: Jean Giraud Originally Posted by: MarB Discovered following behaviour concerning page brakes with very long blocks: Maybe the problem is the construction ? Document would surely help volunteers. Here you are: Pagebrake.sm (71kb) downloaded 47 time(s).
Originally Posted by: MarB Here you are: The long page brakes are not in the attachment ! sin(x0 something => no problem Smath 6179
Originally Posted by: Jean Giraud Originally Posted by: MarB Here you are: sin(x0 something => no problem Smath 6179 We are here in the "RC2: 0.99.6654"-thread. So I thought it would be clearly that I refer to 0.99.6654. Take a look at the video (screen capture) if you don't believe what I am writing. SMath Studio - [Pagebrake.sm] 27.03.2018 15_58_31.mp4 (2,913kb) downloaded 39 time(s).Originally Posted by: Jean Giraud Originally Posted by: MarB Here you are: The long page brakes are not in the attachment ! Sure they are (I uploaded a simplified example):
1 user thanked MarB for this useful post.
When you put the cursor in the description and edit the text, a matching variable in the input data is edited simultaneously. Screenshot: description is edited - Your screen shot is explicit enough, but the document would help more collab to check that particular issue or similar problem. Nobody reported this bug, if it is an Smath bug.
Originally Posted by: Jean Giraud Originally Posted by: MarB Found another issue, while editing the description of a 2D plot: ... Your screen shot is explicit enough, but the document would help ... The document is linked in post #7. And the screen capture in post #9.
Originally Posted by: MarB Originally Posted by: Jean Giraud Originally Posted by: MarB Found another issue, while editing the description of a 2D plot: Not clear w/o the document. Originally Posted by: Jean Giraud Originally Posted by: MarB Discovered following behaviour concerning page brakes with very long blocks: Maybe the problem is the construction ? Document would surely help volunteers. Here you are: Pagebrake.sm (71kb) downloaded 47 time(s). Can repeat both bugs with the provided file on 6654. Oddly enough I was able to enter a description sometimes without effecting the data field if I first clicked within the data field, then immediately clicked the description field. This only worked occasionally and seemed dependent on where I clicked within the data field. |
2 users thanked alyles for this useful post.
on 27/03/2018(UTC), on 27/03/2018(UTC)
Originally Posted by: alyles Can repeat both bugs with the provided file on 6654. Oddly enough I was able to enter a description sometimes without effecting the data field if I first clicked within the data field, then immediately clicked the description field. This only worked occasionally and seemed dependent on where I clicked within the data field. Bug/NObug ... pretty strange, whatever. The document attached does not contain the live Smath part in snippet # 3 There is one known shadow in context You can't define a function starting with 'if' if(a,b,x):=fnct(a,b,x) ... if NOT allowed. Quick tip to get rid of "sometimes without effecting the data field" 1. in the description, type few letters not common to data field 2. once finished the description, zap the fake letters.
Originally Posted by: Jean Giraud The document attached does not contain the live Smath part in snippet # 3 There is one known shadow in context To avoid "shadow in the context" I uploaded a very clean sheet (#7) which shows exactly the behaviour I described. Originally Posted by: Jean Giraud You can't define a function starting with 'if' if(a,b,x):=fnct(a,b,x) ... if NOT allowed.
Really don't know why I should want to define 'if' myself.
Originally Posted by: MarB To avoid "shadow in the context" I uploaded a very clean sheet (#7) which shows exactly the behaviour I described. No bug from [#7], nobody else reported. can't explain the non-explainable.
Originally Posted by: MarB Thank you! Both issues are reproduced and will be fixed asap.
on 28/03/2018(UTC), on 28/03/2018(UTC)
Originally Posted by: mkraska The behaviour of loops with second value seems to have improved. Is this generally fixed or just by chance? Was not my goal. Looks like some refactoring might helped.
Originally Posted by: Andrey Ivashov Was not my goal. Looks like some refactoring might helped. It has some interest, but needs be distinguished by some invention.
"0.99.6661" fixed the x-y plugin problem
