SMath Studio Forum
Bugs & Problems
[SSC-3528] Matrix not inserted after :=
If I type a: then press the matrix toolbutton, then insert on the row.cols dialog. Nothing is inserted. The insertion marker is the reverse-L If I click on the square to get the normal-L, then it works. The problem is what Davide shows below. It is only on Cloud version. [ Created by: Andrey Ivashov Interface translated by: Andrey Ivashov SMath Studio version: 0.99.6622.8829 Application version: 2.5.6624.1857 Last update: 19.02.2018 SMath Studio in the Cloud is a rich on-line math editor with units and graphs support. No need to install anything on your computer or device - all you need is your favorite web-browser. ] It is happening using Opera on Linux, or MS Edge on Win10 or Chrome on Win10. It does not do it with Studio version on win10. Edited by user 03 April 2018 00:22:40(UTC)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Actually I cannot reproduce this issue. Tried with different local settings - matrix inserted ok after using Insert Matrix dialog.
Please could you create a video, so I could see possible specific things?
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Originally Posted by: crun f I type
a:
I too don't get any such behavior. Latest SS 6661 works perfect in this case. Edited by user 30 March 2018 17:35:02(UTC)
Seems not always reproduible ... tomorrow I was able to reproduce immediatly, now only every once in a while (Firefox 59.0.2) Edited by user 30 March 2018 19:02:57(UTC)
It is exactly as Davide shows above.
Problem the same with browsers: Opera on Linux, Edge on Win10, Chrome on Win10
Originally Posted by: crun It is exactly as Davide shows above. Andrey, ndtma reported no such bug. So, Smath is OK, problem is with download. In short: you can't get a 10 x 2 matrix from the palette, is it ???
Seems unlikely ndtma was using the Cloud version (which is what I report the bug in) as it the version numbers don't match.
If he was using the cloud version, then different places or different instances are getting different versions served by the cloud service.
Sorry, It is not the Cloud version I was referring to. Edited by user 04 April 2018 21:08:22(UTC)
SMath Studio Forum
Bugs & Problems
