SMath Studio Forum
Feature Requests
Horizontal spacing of values in matrix
Was thanked: 4 time(s) in 2 post(s)
Hi, i'd like to be able to change spacing between columns in a matrix. My current view is like shown below and it is not very readable. Is there any way to improve it? What about an ability to add some horizontal/vertical grid?
Joined: 01/08/2010(UTC) Posts: 115 Location: Rome Was thanked: 13 time(s) in 13 post(s)
Matrix formatting is through the Davide's plugin. It is not possible to do something directly ...or you need to start to convert numbers in string add the spacing and so on to improve just the formatting but you have no more numbers but string .. it doesn't look a practical idea .
Franco
For display (not for input) you can use the Table Region plugin. Otherwise just generate the input as separate columns and make the matrix using augment() afterwards. This has the advantage of better control on units per column. |
Originally Posted by: m227 What about an ability to add some horizontal/vertical grid? What would that do ? Use Excel instead. Under the hood, a matrix is a one col vector. Personally, no need for freaked matrix.
Lightly shaded columns might be visually effective. Probably one of those "easy to say - 3 days coding to do" things.
[Personally, I'm working on an auto-complete combobox, and its taken 3 days so far, and I'm nowhere near satisfied with it]
Originally Posted by: crun Lightly shaded columns might be visually effective. Probably one of those "easy to say - 3 days coding to do" things. Code what for what ? Only gray scale for 100% color blind.
SMath Studio Forum
Feature Requests
