Was thanked: 4 time(s) in 2 post(s)
Hi, I prepare some sheets for students, after calculating all expressions I would like to hide all results (numbers after equal sign in expressions). If I Lock calculation - old values stay in the sheet. If I disable auto-calculation old values of course are still visible. Is there any option for it: to remove all results after calculation as if auto-calc was never on.
This is a solution. You could use a checkbox region and conditionally formatted labels plugin to create user input to show/hide results. conditionally formatted label.sm (6kb) downloaded 79 time(s).Edited by user 18 April 2018 15:06:11(UTC)
1 user thanked alyles for this useful post.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,649 Location: Italy Was thanked: 1333 time(s) in 877 post(s)
Originally Posted by: m227 If I Lock calculation - old values stay in the sheet. Great feature of Smath !3 ways to skin this cat.
Originally Posted by: alyles This is a solution. You could use a checkbox region and conditionally formatted labels plugin to create user input to show/hide results. Thank you for help alyles. I'd rather wanted something more global - one click - disable all results. In a meantime I did it in my small helper program. Here it comes: Original file / After changing results to blanks / After removing results: Program to download: SMath_Helpers.7z (44kb) downloaded 25 time(s).Davide/Jean, I was looking for something more global and not to change existing files (so now I can select batch of my files to hide results in, and every result is removed). No plug-ins required Edited by user 18 April 2018 16:39:08(UTC)
Originally Posted by: m227 I prepare some sheets for students, YES/BUT ... you are trying freak Smath [an advanced CAS] to a 2*3=6 system !
Originally Posted by: Jean Giraud Originally Posted by: m227 I prepare some sheets for students, YES/BUT ... you are trying freak Smath [an advanced CAS] to a 2*3=6 system ! I could use MS Word for such tasks but SMath does calculations too (besides of presenting them in a nice form). I hope, the author won't mind. You don't have to drive 300km/h your Lamborghini all the time.
