Offline koodakk3
#1 Posted : 20 April 2018 19:07:35(UTC)
koodakk3
United Kingdom
I have an issue with the units for the calculation shown in the image
g1cj2NEcln4zHURXUBGcNiHBPCKhnUzsR9Ug1hGhTIyLlglUdDiF1-X7Q27R_XR79HYTnNL34vK1gTXIlLAQ=w1280-h950.jpg
edit: image attached
The calculation of 200/d_eff gives a result of 192.96, which is in units of m^-1, however I need the units in mm^-1 (0.19296) since d_eff is in units of mm. It seems like it is impossible to change it. I have tried all the options in the tools->calculations settings.
There is a similar post to mine on the forum, but it doesn't really answer my question:
https://en.smath.info/fo...-of-the-calculation.aspx
Can you please advise on this? I seem to be able to change the units from m to mm, when the units are in the numerator, but not when the units are in the denominator.
Thanks in advance.
Iura
Edited by moderator 21 April 2018 18:48:38(UTC)  | Reason: marked as solved
Offline PompelmoTell
#2 Posted : 20 April 2018 19:32:07(UTC)
PompelmoTell
The procedure is well illustrated in the interactive guide "Interactive SMath Handbook" (by Martin Kraska) downloadable from the menu -> tools -> plugins. It is valid for both numerator and denominator units
Click a result. Then a placeholder appears to the right of the result. Set the cursor to the placeholder. Type "1/mm" and confirm the unit "mm" in the dynamic assistant by pressing [Tab]
thanks 2 users thanked PompelmoTell for this useful post.
on 20/04/2018(UTC),  on 21/04/2018(UTC)
Offline koodakk3
#3 Posted : 23 April 2018 11:30:37(UTC)
koodakk3
United Kingdom
Hi Sergio,
Thanks for your quick reply, however the units of 1/m still remain although I have added 1/mm like you suggested before.
Please find attached the image
zy38Yrv06OUK7Y_vpyRQCXJSOiHMze3z0MenzfC32wJ8o8hXAzJnYaJ3sH0joL3YbKscaInpRZLPDkEomy5U=w1280-h950.jpg
Thanks
Iura
Edited by moderator 23 April 2018 12:00:45(UTC)  | Reason: Not specified
#4 Posted : 23 April 2018 12:01:47(UTC)
Was thanked: 1338 time(s) in 878 post(s)
Hello Iura,
please right-click that region and check if you have the "Ignore units" option in the context menu enabled; in this case uncheck it.
Edited by user 23 April 2018 12:03:29(UTC)  | Reason: Not specified
on 23/04/2018(UTC)
Offline koodakk3
#5 Posted : 23 April 2018 12:04:52(UTC)
koodakk3
United Kingdom
Originally Posted by: Davide Carpi Go to Quoted Post
Hello Iura,
Hey,
Yes, the Ignore units option was enabled. Thank you, this has solved my query. Good
SMath Units1.pdf (20kb) downloaded 19 time(s).
Thanks
Iura
#6 Posted : 23 April 2018 12:06:37(UTC)
You're welcome Good
Offline koodakk3
#7 Posted : 23 April 2018 13:43:06(UTC)
koodakk3
United Kingdom
You're welcome Good
I am facing a similar issue again. Please see the link to the image below. This time, I need the result to come out in units of N, however due to a number of reasons this doesn't quite workout. Can I completely cancel the display of units and type a text box of my own next to it?
https://drive.google.com...Ea1F77ULgCTtMtXM3Fwlz2hC
#8 Posted : 23 April 2018 16:28:34(UTC)
Two things:
1. Better attach the *.sm document
2. for faster/better image
Download freeware "WinGrab", set some key options, put it in task bar.
_ click WinGrab from task bar
_ click 'start capture'
_ click 'Selection tool', adjust the rectangle
_ crop image
_ save as PNG in a dedicated Snippets in C:\ Directory
Offline alyles
#9 Posted : 23 April 2018 16:39:46(UTC)
alyles
United States
As Jean said, it would really help out if you could attach the .sm file. It appears that there is an error somewhere in your calculation. The units come out to kg^(1/2)*m^(3/2)/s. The unit N is kg*m/s^2. So your result is not equivalent to Newtons.
This could simply be an error in variable definition (incorrect/missing units) or there may be an error in your arithmetic resulting in erroneous result.
Edited by user 23 April 2018 16:41:40(UTC)  | Reason: Not specified
#10 Posted : 23 April 2018 17:11:33(UTC)
PompelmoTell
It looks like the typical dimensional formula situation. In these formulas the quantities must be entered with a specific unit of measure and the result is read with specific units of measure. Usually I act like this:
Guest (3)
