Offline AdiS
#1 Posted : 02 May 2018 17:03:27(UTC)
AdiS
I have a problem. Why does Gy or J appear near tonne?
NH.3_ex_c_r:NH.3_ex_c*M.ex_c=1227.6454 Gy tonne
NH.3_ex_c_r:NH.3_ex_c*M.ex_c=1.2276*10^6 J tonne
Offline alyles
#2 Posted : 02 May 2018 18:37:53(UTC)
alyles
United States
Hi Adis,
We'll need more information to help you. could you please post the .sm file you're referencing?
#3 Posted : 02 May 2018 22:23:48(UTC)
"tonne" reminds me a Mathcad bug in the German version.
It also appeared in the Mathsoft "Fourier model" English US version.
Offline AdiS
#4 Posted : 03 May 2018 10:47:19(UTC)
AdiS
Originally Posted by: alyles Go to Quoted Post
Hi Adis,
Proiect master MB1.sm (39kb) downloaded 24 time(s).
#5 Posted : 03 May 2018 13:11:31(UTC)
Was thanked: 1334 time(s) in 877 post(s)
In your file I can't find neither NH.3_ex_c nor M.ex_c
Offline AdiS
#6 Posted : 03 May 2018 13:34:53(UTC)
AdiS
Sorry wrong files.
Problem.sm (106kb) downloaded 16 time(s).
Real result is 1.2276 tone. 1 tone = 1000 kg
Edited by user 03 May 2018 13:45:59(UTC)  | Reason: Not specified
Offline alyles
#7 Posted : 03 May 2018 17:03:34(UTC)
alyles
United States
I think i fixed the issue. See attached.
I have disabled some of your manual unit definition and performed some cleanup.
Generally you do not want to overwrite units already defined within Smath and you were re-defining already defined units.
The issue, I believe came with your definition of H.ii_c. You applied units to the result and toggled ignore units. This made it seem like the result evaluated to kJ/kg when in fact it was unitless.
This propagated through to the result in question.
Problem_alyles.sm (121kb) downloaded 20 time(s).
#8 Posted : 03 May 2018 17:33:53(UTC)
Above my head ! why do we still have tonne ?
For God sake what's that in Smath ?
What was it in Mathcad ?
What is the difference between "Titration and MassBalance" ?
In case of interest, PseudoInverse works fine in Smath.
Matrix PseudoInverse.sm (112kb) downloaded 18 time(s).
Offline alyles
#9 Posted : 03 May 2018 17:40:41(UTC)
alyles
United States
1 tonne is defined as 1000 kg. Same thing as a Mg.
#10 Posted : 03 May 2018 18:12:18(UTC)
Thnks alyless,
ton(long), ton(short), tonne(metric)
#11 Posted : 03 May 2018 19:05:51(UTC)
ton(short)
short is t Good
Edited by user 03 May 2018 19:07:32(UTC)  | Reason: Not specified
Offline AdiS
#12 Posted : 04 May 2018 07:10:03(UTC)
AdiS
Thank you very much! The original file was worked in Mathcad. After conversion to SMath Studio, some errors occurred. In the future, I will only use the defined units.
#13 Posted : 04 May 2018 07:26:54(UTC)
Oh !, you are the man of science in there.
I know about titration from past professional [Process Control & Instrumentation]
Not so easy ... so and so ... generally Ph control.
Did you visit PseudoMatrix ? Any use for your project ?
