SMath Studio Forum
Questions
Weird Unit Conversion kg <> ton
Joined: 04/12/2017(UTC) Posts: 61 Was thanked: 2 time(s) in 2 post(s)
The question is simply clear ...its should be a matter of removing or adding x3 zeros aMIR.sm (11kb) downloaded 9 time(s).
Simple as the question |
Thanks ...but can you tell me what is the wrong in this kg <> ton ...it should just reduce the power to 10 from 8 to 3 without changing the values
Originally Posted by: ioncube Thanks ...but can you tell me what is the wrong in this kg <> ton ...it should just reduce the power to 10 from 8 to 3 without changing the values I missed it... You have to use 't (metric ton) because 'ton here is the US "short ton" Edited by user 14 May 2018 12:10:52(UTC)
I think its the problem ...I was expecting MetricTons Problem solved
SMath Studio Forum
Questions
