Jean, Can you (and EVERYBODY who solves a problem) please STATE the problem with all necessary details, EXPLAIN the solution and DOCUMENT every step. This way will have a wider group of users!!! Otherwise, the effort is a cryptic document that the user tries to reverse engineer to decode it and spends much more time than available. Thank you, Basile
1 user thanked Basile for this useful post.
Originally Posted by: Basile Jean, Can you (and EVERYBODY who solves a problem) please STATE the problem with all necessary details, EXPLAIN the solution and DOCUMENT every step. This way will have a wider group of users!!! Otherwise, the effort is a cryptic document that the user tries to reverse engineer to decode it and spends much more time than available. Thank you, Basile If it works as delivered, just need to explore for more specific use. "... reverse Engineer..." what ? "... to decode ..." what? Augmented version. Maths Pulse [Square].sm (43kb) downloaded 21 time(s).
