SMath Studio Forum
Samples
Solve Contour [Electron fnct]
Originally Posted by: Jean Giraud Few more techniques/tools in this Smath document. ... lobes added Contour SOLVE [user].sm (62kb) downloaded 23 time(s).
Hello Jean, Just for the record, without to much insight into the problem. Unfortunately, your recent examples do not work for me. Regards, Radovan Edited by user 28 June 2018 15:50:26(UTC)
Regards, Radovan Hello Doctors ! please help Radovan. The error message does not indicate an error in the transmission. Please, re-download these [3] that have same solver or otherwise. Jean Project Solve Ejector.sm (20kb) downloaded 21 time(s). Contour SOLVE [at(2)].sm (173kb) downloaded 22 time(s). Contour SOLVE [user].sm (66kb) downloaded 19 time(s).
Hello Jean, I just removed at(). Is this all right? Regards, Radovan |
I just removed at(). Is this all right? For sure, more than correct as your solve(,,) gets pair wise solutions. Yes, the lobe is symmetric around the 0 datum. Jean
Originally Posted by: Jean Giraud For sure, more than correct as your solve(,,) gets pair wise solutions. ... now I get pair wise solutions. But not augment !
SMath Studio Forum
Samples
