Was thanked: 16 time(s) in 7 post(s)
I have been trying to figure out keyboard shortcuts for SMATH. I have been using these- https://smath.info/wiki/Keyboard%20shortcuts.ashxAre there more? Can people add more to the wiki list? For example, it would be useful to be able to matrix element assignemnts instead of always clicking the matrix panel to the right. Is there a way to see the syntax to the panel buttons to figure it out? Thanks in advance Dennis |
Quote:For example, it would be useful to be able to matrix element assignemnts instead of always clicking the matrix panel to the right. Please take a look at the following file. Matrix Example.sm (7kb) downloaded 15 time(s).Edited by user 10 July 2018 23:21:33(UTC)
alyles:
THANKS! The last bit is what I needed to get el(3) instead of el(2).
Dennis
Originally Posted by: sinneD Is there a way to see the syntax to the panel buttons to figure it out? Just type ... M:=matrix(3,6) to 3x6 matrix of 0's The palette is matrix 6x6 empty matrix Maths Symbols AltKey.sm (50kb) downloaded 46 time(s). Maths Symbols.sm (63kb) downloaded 40 time(s).
Jean Giraud-
Thank you for posting those. I did not initially have the XY Pltting regions (? plugin name) loaded, perhaps that would have been helpful too.
Were those posted here already in another post/discussion? I tried searching but perhaps my search-fu is rusty. What suggestions for keywords seaching might you have for future.
Dennis
Originally Posted by: sinneD What suggestions for keywords seaching might you have for future. Honestly: from the volume of Smath documents I have either created or converted from MCD , I just use the palette and few universal ones. The most useful [int, deriv, Σ, Π ...] are more awkward from function call than from the palette.
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
Appendix C of the SMath Handbuch has a table of keyboard shortcuts. It is in german but there are translation sites out there. |
