Offline sinneD
#1 Posted : 11 July 2018 00:59:22(UTC)
sinneD
Was thanked: 16 time(s) in 7 post(s)
I have an include file with a bunch of functions and variable definitions in it. Within one of my functions is a 'cases' and a bunch of if/thens that makes it REALLY long.
Are better ways to script or format the syntax for something like this? The sheer vertical size of this trips me up sometimes and I need to get my bearigns to navigate it.
Thanks
Dennis
#2 Posted : 11 July 2018 03:13:29(UTC)
Originally Posted by: sinneD Go to Quoted Post
Are better ways to script or format the syntax for something like this ?
For horizontal, use if/otherwise instead of if/else
Open the collapsed area [mapR(x), mapG(x),mapB(x)].
Image Rainbow Colormap [Electron].sm (253kb) downloaded 15 time(s).
Offline sinneD
#3 Posted : 11 July 2018 04:09:10(UTC)
sinneD
Jean Giraud-
THANK YOU! that will help me make things so much cleaner. I need to take some time to get my head around the way I have it now to clean up.
Question- at the value of say 64, do the sucessive (32≤x)&(x≤64) and (64≤x)&(x≤96) have a conclict? should one of those terms be a less than instead of a less than or equal too operator?
Dennis
#4 Posted : 11 July 2018 05:22:22(UTC)
... can't tell w/o the document. On top, you complicate matters
Can't you mange f(x) ... linterp(X,Y,x)
... or part of the document that produces something.
Offline sinneD
#5 Posted : 11 July 2018 17:19:35(UTC)
sinneD
Jean Giraud-
My question is about the bolean expressions in your example, within the mapR(x) section. Two sucessive expressions have a common intersection point throughout.
1. The upper limit of the first expression is a less than or equal evaluation of a number.
2. The lower limit of the next expression is a greater than or equal to the same number.
What happens when the value for the expression is exactly equal to the number?
I thought only one of the two expressions could be an 'equal to' statement at the same limit point.
Dennis
#6 Posted : 11 July 2018 19:14:55(UTC)
... mistakes in the last two posts, deleted.
The two segments for interpolation.
Dennis.sm (12kb) downloaded 14 time(s).
Offline sinneD
#7 Posted : 14 July 2018 03:44:53(UTC)
sinneD
Jean Giraud-
Thanks for that explanation. I actually learned a whole bunch more functions from that too!
Dennis
Offline oscampo
#8 Posted : 14 July 2018 07:54:32(UTC)
oscampo
Colombia
You can use areas to separate portions of code.
As an example, please, look this game that I developed and has a lot of lines of code
Regards!
Guest (2)
